Contacting HomeSeer This Week
See more
See less
Error 380 Invalid property value
  • Error 380 Invalid property value
    System was working and now I get this when I try to start the config.
    Removed the plugin, deleted devices, DL a new copy of 3.1.5. Still get the same error. The config screen has no titles and no options.
    No change in hardware.
    Don
    Don
    There has to be some corruption in the config file. Do you have a backup copy of it? If not you can do one of these options:
    1. delete the hspi_hauppauge_config.ini file and restart HS. Re-enter all the config info
    2. Set the debug level to level 1 and restart Homeseer - send me the HS log and the config file and I should be able to repair the corruption
    Bryan
    (Config is in my profile)
      Done that
      I figured the config file got corrupted so I deleted and still got the same thing. Same after deleted and then re-installed the plugin.
      I currently have it set to the highest logging level. Will send a copy to you.
      Probably won't be until tomorrow evening.
      Don
