Contacting HomeSeer This Week
See more
See less
Startup questions and difficulties
  • Startup questions and difficulties
    I'm trying to explore the capture plugin and I think I follow the basic flow. I have an old Win TV PCI adapter that I stuffed into the PC and download the latest XP WDM drivers from Hauppauge site. I can run their TV application so it looks like the hardware and drivers are working fine.
    First thing I wanted to do after the setup was to look at the Capture Preview. I did not see any button on the setup page to get there or any exe of that name in the downloaded zip file. How does one start it?
    I then went to capture an impage using the camera.asp. When I click on the camera name there is a delay of number of seconds, page refresh, and still only an icon placeholder on the screen.
    I then triggered my camera motion device to get a picture that way. I looked in the \Capture folder and did see a file which when viewed is solid blue execept some imposed text in the corners. The HS log also had the following
    <pre class="ip-ubbcode-code-pre">
    10/15/2004 6:30:27 PM~!~Device control from menu~!~v7 On
    10/15/2004 6:30:34 PM~!~Device control from menu~!~v7 Off
    10/15/2004 6:32:28 PM~!~Hauppauge Capture Debug Level 2~!~camera_switch - Found our camera that should be turned on v5 Computer Television
    10/15/2004 6:32:28 PM~!~Send X10 from ext interface~!~V5 On dim: 0 extra: 0
    10/15/2004 6:32:29 PM~!~CaptureUtility Debug L2~!~Form_Load - form loaded - Init value is True
    10/15/2004 6:32:30 PM~!~CaptureUtility Debug L2~!~Form_Load - CapPreview Form Loaded
    10/15/2004 6:32:30 PM~!~CaptureUtility Debug L2~!~Switching to camera Computer Television
    10/15/2004 6:32:30 PM~!~CaptureUtility Debug L2~!~Entered ResetCameraConfig() for camera Computer Television Not Streaming - Snap in progress False - Capture filter enabled False
    10/15/2004 6:32:31 PM~!~CaptureUtility Debug L2~!~ResetCameraConfig - Adding brightness:5000
    10/15/2004 6:32:32 PM~!~CaptureUtility Debug L2~!~Brightness-0-10000-39-5000(10000) Contrast-0-10000-39-5000(5000) Hue-0-10000-39-5000(5000)
    10/15/2004 6:32:32 PM~!~CaptureUtility Debug L2~!~Saturation-0-10000-39-5000(5000) Sharpness-0-10000-39-5000(5000) Gamma-0-10000-39-5000(5000)
    10/15/2004 6:32:32 PM~!~CaptureUtility Debug L2~!~ Video Source-0/Video SVideo Channel-4 V Size-640 x 480 Color Format-RGB24
    10/15/2004 6:32:32 PM~!~CaptureUtility Debug L2~!~TakePicture Hauppauge - Starting Initial Timer -100
    10/15/2004 6:32:33 PM~!~CaptureUtility Debug L2~!~tmFormTimer - Timer fired for Form Timer - Interval was:100
    10/15/2004 6:32:36 PM~!~CaptureUtility Debug L2~!~tmFormTimer - Starting preview
    10/15/2004 6:32:42 PM~!~CaptureUtility Debug L2~!~tmFormTimer - Connected to drivers
    10/15/2004 6:32:49 PM~!~CaptureUtility Info~!~Snapping Image set 1 for Computer Television C:\Program Files\HomeSeer\html\Capture\Computer Television_2004-10-15_18-32-45.jpg
    10/15/2004 6:33:09 PM~!~CaptureUtility Info~!~tmCaptureImage - Starting AVI capture for 15 seconds - C:\Program Files\HomeSeer\html\AVI\Computer Television_2004-10-15_18-32-45.avi
    10/15/2004 6:33:12 PM~!~CaptureUtility Error~!~An unexpected error occured in the tmCaptureImage_Timer(1620) function/subroutine: [-2147417848 - Automation error
    The object invoked has disconnected from its clients. ]
    10/15/2004 6:33:13 PM~!~Hauppauge Capture Info~!~oCapture_CaptureError - shuting down utilities - Retry Count is 0
    10/15/2004 6:33:13 PM~!~CaptureUtility Debug L2~!~Entered Class terminate
    10/15/2004 6:33:32 PM~!~Hauppauge Capture Debug Level 2~!~name() resetting CaptureUtility
    </pre>
    I have no camera connected and expect to just use the tuner to see how this thing flows. Any advice on getting started?
    Michael,
    It should show up on the menu bar in the HS GUI. I actually use mcsMenu to hide it and then add the two items (config and preview) to the mcsMenu menu. I still maintain there is a bug in the menu bar of the HS GUI, it sometimes stops displaying after about 7 plug-ins. Take a look in mcsMenu to see if you see the plug-in there.
    That error is similar to something I got when I upgraded to WMP10. Try selecting different codecs (on the camera settings tab) some of them just don't work. I use Indio Video 5.10.
    Bill
      There is a couple of things to check. The capture folder has to be in ?:\HomeSeer\Html\SomeFolder (where ? is the driver HS is installed on and SomeFolder is the name you give to the capture folder). HS web server will only serve files under the html folder structure.
      As far as the blue picture goes check to make sure the camera your using is set tot he proper video source (eg: composite / TV Tuner with proper channel) - this depends on how you have the physical video/audio signals going intot he card.
      Bryan
      (Config is in my profile)
        I was able to get the preview via mcsMenu and then able to get the settings correct to get the image from the tv tuner. Preview is fine now.
        Onto the Camera.asp...
        When I click the button for the TV Tuner, which is the only button setup and showing, I do observe the image in the capture folder, but the icon X does not change. I looked at the camera.asp and it looks as if it is expecting the name of the file in the [Thumbs] group of the ini with key of LastImageName. There is no value for this key in the .ini file. There is no key that has a name similiar to the name under which the file was captured. Computer Television_2004....jpg.
          Can you post the contents of your hspi_Hauppauge_Capture.ini file? I should be able to see if there is a problem with the way things are configured.
          Bryan
            Traveling again. I'll be back in 2 weeks and can pick up on it then.
              [ZoneCameraAssmts]
              Hauppauge Capture Main Alarm=Main Alarm~~False~0
              [Settings]
              BaseCode=$
              CaptureCardCount=1
              CaptureCard=0
              VideoCodec=0
              AudioCodec=0
              AutoCameraOff=0
              VideoSize=0
              VideoSizeW=240
              VideoSizeH=240
              StatusFailSafe=60
              CapUtilResetCount=20
              ImageUtilResetCount=50
              DelayAfterConnect=50
              FontSize=10
              NameLoc=0
              DateLoc=2
              TimeLoc=8
              AudioMuteLine=12
              AudioMute=True
              AudioInput=0
              StreamingProfile=0
              TextColor=blue
              BGColor=white
              TextOpacity=50
              BGOpacity=30
              MSDevType="Camera Motion"
              DevCount=1
              NumberOfImagesToTake=1
              MsBetweenImages=1000
              JPGQuality=80
              VideoFormat=1
              Width=640
              Height=480
              PreCaptureType=
              PostCaptureType=
              CameraDeviceType=Camera
              [Options]
              MsgLevel=4
              [CameraSettings]
              Default Camera Settings=0~4~4946~5000~5000~5000~C:\Program Files\HomeSeer\html\Capture\~Default Camera Settings~1000~500~1~0~0~5000~5000~5000~5000~5000~15~15~Defau lt Camera Settings~C:\Program Files\HomeSeer\html\AVI\~50~1~1~1~1~1~1
              Computer Television=1~3~1452~5000~6935~5000~C:\Program Files\HomeSeer\html\Capture\~Computer Television~1000~500~1~0~0~5000~5000~5000~5000~5000~15~15~Com puter Television~C:\Program Files\HomeSeer\html\AVI\~50~1~1~1~1~1~1
              [Thumbs]
              SnapImageCnt=1
              AVISeconds=-1
              ForceCameraOn=False
              Width=200
              Height=200
              Quality=75
              PageSize=8
              Columns=4
              ShowFilenames=False
              LastCapFolderFile=C:\Program Files\HomeSeer\html\Images\
              ForDays=0
              FromHour=18
              NameLoc=0
              DateLoc=3
              TimeLoc=6
              FontSize=8
                Thanks for posting the ini contents. Your right, a key called "LastImageName" is created in the [Thumbs] section of the ini file that contains the name of the last image captured. This is set after the image has been saved.
                A couple of questions:
                1. when you bring up the camera.asp page, the button generated for the camera should be called "Computer Television" right?
                2. the number of seconds for AVI is set at -1 right? This tells the plugin to use the default number of seconds configured for the camera to record an AVI - for this camera that is set to 15 seconds. I noticed that you have not selected the Video or Audio Codec used to compress the AVI. If the plugin attempts to record an AVI with incorrect A/V codec's unpredictable results will occur. As a first step, enter 0 for the AVI Seconds before you click the "Computer Television" button to snap a picture.
                If you still don't get an image go into the plugins config screen and at the top of the form select "Debug Level 1 Messages" for the message level - click Ok. Snap a image using the Camera.asp page and send me the snippet of the ah.log (HomeSeer log file in the HomeSeer root folder) when the image was snapped. Send to bstein@accesscomm.ca
                Bryan
