Contacting HomeSeer This Week
See more
See less
Inconsistant Success
  • Inconsistant Success
    First of all I would like to say that I love this plug in. When it works it does exaclty what I want.
    The problem is that it will work great (capture pictures and video) for a while and then stop working. Stoping starting HS does not seem to get it going agian. I just keep going into config and preview, I don't change anything, but at some point it starts working again. Here is a snippit from my log file. Anyone have any ideas?
    3/15/2005 4:33:07 AM~!~X10 Received~!~A1 (Basement Motion) A On
    3/15/2005 4:33:07 AM~!~Hauppauge Capture Debug Level 2~!~Request to take picture using camera Basement Camera
    3/15/2005 4:33:07 AM~!~Hauppauge Capture Debug Level 2~!~camera_switch - Found our camera that should be turned on r1 Basement Camera
    3/15/2005 4:33:07 AM~!~Info~!~Exec command: Basement Camera On dim: 0 extra: 0
    3/15/2005 4:33:08 AM~!~CaptureUtility Debug L2~!~Form_Load - form loaded - Init value is True
    3/15/2005 4:33:09 AM~!~CaptureUtility Debug L2~!~Form_Load - CapPreview Form Loaded
    3/15/2005 4:33:09 AM~!~CaptureUtility Debug L2~!~Switching to camera Basement Camera
    3/15/2005 4:33:09 AM~!~CaptureUtility Debug L2~!~Entered ResetCameraConfig() for camera Basement Camera Not Streaming - Snap in progress False - Capture filter enabled False
    3/15/2005 4:33:09 AM~!~CaptureUtility Debug L2~!~ResetCameraConfig - Adding brightness:-12
    3/15/2005 4:33:10 AM~!~CaptureUtility Debug L2~!~Brightness--128-127-1--12(-24) Contrast-0-255-1-121(121) Hue--128-127-1-0(0)
    3/15/2005 4:33:10 AM~!~CaptureUtility Debug L2~!~Saturation-0-255-1-113(113) Sharpness-3-7-1-3(3) Gamma-3-7-1-3(3)
    3/15/2005 4:33:10 AM~!~CaptureUtility Debug L2~!~ Video Source-2/Video Composite Channel-4 V Size-640 x 480 Color Format-RGB24
    3/15/2005 4:33:10 AM~!~CaptureUtility Debug L2~!~TakePicture Hauppauge - Starting Initial Timer -1000
    3/15/2005 4:33:11 AM~!~CaptureUtility Debug L2~!~tmFormTimer - Timer fired for Form Timer - Interval was:1000
    3/15/2005 4:33:11 AM~!~CaptureUtility Debug L2~!~tmFormTimer - Starting preview
    3/15/2005 4:33:12 AM~!~CaptureUtility Debug L2~!~tmFormTimer - Connected to drivers
    3/15/2005 4:33:12 AM~!~CaptureUtility Info~!~Snapping Image set 1 for Basement Camera C:\Program Files\HomeSeer\html\Capture\Basement Camera_2005-03-15_04-33-12.jpg
    3/15/2005 4:33:12 AM~!~CaptureUtility Error~!~An unexpected error occured in the tmCaptureImage_Timer(1190) function/subroutine: [1000 - Error 'b' in SaveFrameJPG!]
    3/15/2005 4:33:13 AM~!~Hauppauge Capture Info~!~oCapture_CaptureError - shuting down utilities - Retry Count is 0
    3/15/2005 4:33:13 AM~!~CaptureUtility Debug L2~!~Entered Class terminate
    3/15/2005 4:33:29 AM~!~Hauppauge Capture Debug Level 2~!~name() resetting CaptureUtility
    You may want to try increasing the "Delay after Connect" value by 100 ms. This error can occur if the image capture is attempted before the drivers are ready to accept the request.
    Bryan
    (Config is in my profile)
      Seems to work
      Sorry for the delay, but thanks! It seems to work much more consistantly now!
