Contacting HomeSeer This Week
See more
See less
DiGiCam cards
  • DiGiCam cards
    Does this plugin support the multiport DiGiCam cards?
    The WebCam plugin works fine until HS is restarted then only 1 instance (port) of the card is displayed.
    Version 4.1.1 should support multiple cards but only one card can be used for camera input. The other card can be used by other applications.
    Bryan
    (Config is in my profile)
      Multiple ports - one card?
      The Digicam card has mulitple inputs (4-16) on one card. Is this supported? I installed from the updater to give it a try, it doesn't appear to be supported. Each input shows as a card. 4 cards listed all with the same name.
      If i'm missing the boat in configuration and it is supported just let me know and I will actually read the install. After all i'm a nerd and nerd stands for Never Ever Read Directions.
        I know what you mean (NERD). When all else fails than I red the directions
        If the Digi card shows up as seperate devices then only one can be used in the configuration. I guess I'll have to retrofit the plugin to actually support multiple capture cards simultanously. It will take a while to do that though - it's a fair bit of work but not hard to to.
        Bryan
