Contacting HomeSeer This Week
See more
See less
New install - Errors
  • New install - Errors
    ~!~Hauppauge Capture Error~!~An unexpected error occured in the InitHW(480) function/subroutine: [9 - Subscript out of range]
    ~!~Hauppauge Capture Debug Level 2~!~Request to show CapConfig Received
    ~!~Hauppauge Capture Error~!~An unexpected error occured in the Form_Load(70) function/subroutine: [9 - Subscript out of range]
    And others.. any ideas?? I instaled from the updater, rebooted pc.
    TrOjAn
    this log is from startup
    19/02/2006 23:39:46 Info Done initializing plug-in Hauppauge Capture
    19/02/2006 23:39:46 Hauppauge Capture Error An unexpected error occured in the InitHW(480) function/subroutine: [9 - Subscript out of range]
    19/02/2006 23:39:46 CaptureUtility Debug L2 Entered Class terminate
    19/02/2006 23:39:46 CaptureUtility Debug L2 Got all video info
    19/02/2006 23:39:46 CaptureUtility Debug L2 Getting WDM Streaming Profiles for 26 profiles
    19/02/2006 23:39:45 CaptureUtility Debug L2 Getting Video Inputs info
    19/02/2006 23:39:45 CaptureUtility Debug L2 VideoCaps info not supported by driver
    19/02/2006 23:39:45 CaptureUtility Debug L2 Getting Supported Video formats info
    19/02/2006 23:39:45 CaptureUtility Info CaptureUtility Version: 4.1.1 - Retrieving info from capture card - Connected(True)
    19/02/2006 23:39:43 CaptureUtility Debug L2 Form_Load - form loaded - Init value is False
    19/02/2006 23:39:43 Hauppauge Capture Info Registering menu items
    19/02/2006 23:39:43 Hauppauge Capture Info HSPI_HAUPPAUGE_CAPTURE Version: 4.1.1 - initializing I/O
    19/02/2006 23:39:43 COM Plugin Calling InitIO
    19/02/2006 23:39:43 Hauppauge Capture Info HSPI_HAUPPAUGE_CAPTURE - register callback complete.
    19/02/2006 23:39:42 Info Initializing Plug-in: Hauppauge Capture
    19/02/2006 23:39:42 Info Interface Hauppauge Capture is running as a trial, 30 days remaining.
    Trojan,
    What hardware are you using? The WebCam plugin and this plugin use the same basic connections so I wondering if you have the proper prerequisite software loaded like the latest DirectX, etc.
    -Rupp
      Rupp, I would have thought so, its an xp pro setup with service pack 2, running hs2 with one event and one plugin (webcam now changed to hauppage) other than the cm12.
      And in case your wondering.. yes it worked fine on hs1.7.44
        Soooooo no other ideas anyone??
        I have confirmed my VA11A will work with this plugin as it uses wdm drivers.. in fact I am streaming now using another VA11A on another pc using streaming software with WDM.
        Does anyone know what these errors mean, could do with a few start points to sort it out.
          I'll bet it works fine using a Hauppauge card...
          ______________________________
          Skibumsplace - Locate Me
            I doubt that as its giving errors on startup.. the config page loads but theres not a lot I can do as it hasnt fired up fully because of the errors.
            I have tried to locate an older version but as its in the updater you only get one choice..
              I have a hauppauge card installed in my Homeseer machine....
              Do I hear any sort of wager coming from that side of the pond?
                So, yet more money on a card, so my webcam plugin, 39$ wasted, new card and then another plugin.. jeez this just keeps adding up...
                  especially after you payup.... LOL
                    Give Bryan a chance to see the post. He might just have an answer.
                      Kyham.. he has seen it, was on earlier
                        AVI Thumbnails
                        Originally posted by Skibum
                        Say Don... How are you getting thumbnails of your videos? I can't seem to make it happen.. Thanks
                        UPDATE: I had to make an event that first captures a still, and then captures video.. Is this the correct way?
                        In the Touchpad config menu as in AVI.jpg then create a button as in AVI001.jpg
                        If you are using the Touchpad Americana format, the buttons and ASP page is in the DOWNLOAD section on my system. I just updated all the files there yesterday.
                        If you are using the standard HS web format as Bryan supplies, it should work using the path and asp page as in AVI001.jpg. The thumbnails are created on the fly every time that ASP page is called.
                        Bryan's routine shows all of them. My mod to his page only lists the last 6.
                          Can I get you to manually edit the hspi_Hauppauge_capture.ini file in the config folder and change the line "MsgLevel=2" to "MsgLevel=0" (no quote marks) and then restart HomeSeer. Email the log file and the ini file to me at bstein@accesscomm.ca and I'll see If I can see what is going wrong. It appears that the error when loading the config form indicates that there is a problem with the video codec's on your system.
                          Do you happen to have more than one capture device in your system? Look in device manager and see what is listed under "Sound, video and game controllers".
                          TrOjAn
                          Bryan
                          (Config is in my profile)
                            Bryan,
                            Looking in the .ini file all I have is this:
                            [ZoneCameraAssmts]
                            Hauppauge Capture Main Alarm=Main Alarm
                            [Settings]
                            BaseCode=[
                            CaptureCardCount=2
                            I dont have that line... I will add it and see what happens. YES I have a VA11A and also an ATI all in wonder 128
                            Thanks, TrOjAn
                            Log::::
                            21/02/2006 09:06:33 ~!~Info~!~Interface Hauppauge Capture is running as a trial, 29 days remaining.
                            21/02/2006 09:06:33 ~!~Info~!~Initializing Plug-in: Hauppauge Capture
                            21/02/2006 09:06:33 ~!~Hauppauge Capture Info~!~HSPI_HAUPPAUGE_CAPTURE - register callback complete.
                            21/02/2006 09:06:33 ~!~COM Plugin~!~Calling InitIO
                            21/02/2006 09:06:33 ~!~Hauppauge Capture Info~!~HSPI_HAUPPAUGE_CAPTURE Version: 4.1.1 - initializing I/O
                            21/02/2006 09:06:33 ~!~Hauppauge Capture Info~!~Registering menu items
                            21/02/2006 09:06:33 ~!~Hauppauge Capture Error~!~An unexpected error occured in the initVideoSettings(30) function/subroutine: [429 - ActiveX component can't create object]
                            21/02/2006 09:06:33 ~!~Hauppauge Capture Error~!~An unexpected error occured in the InitHW(320) function/subroutine: [9 - Subscript out of range]
                            21/02/2006 09:06:33 ~!~Info~!~Done initializing plug-in Hauppauge Capture
                              If the MsgLevel is not in the ini file, then add these two lines to the ini file:
                              [Options]
                              MsgLevel=0
                              Bryan
