Contacting HomeSeer This Week
See more
See less
Number of capture cards
  • Number of capture cards
    Can I use more then 1 capture card? What about more than 1 usb capture device (The ones from x10 VA11's I think they are)
    If not how are people getting around this to be able to use more than 1 capture. I have two va11'a installed and when I started hs, I got a pop up saying I need to select my capture card. I was hoping that when I select my cameras in the camera tab, that I could say what card to use, however the source dropdown list is empty.
    Also I have one of those 4 input cards, what driver are people using. the one that cam with my card is not working
    Kirk
    http://cleverhouseautomation.ca
    http://southcoastwebsitedesign.ca
    Right now the plugin only allows the use of one capture card at a time. I'm planning to develop the ability to select which capture card to use by camera in the future.
    Bryan
    (Config is in my profile)
      I am looking at this capture card....
      This capture card comes with software and also has a composite output. I want to be able to watch my camera's on any tv in the house and also view from the computer. Would this card be able to interface into homeseer?
      http://www.bluecherry.net/store/prod...&cat=18&page=1
      Josh
        It appears this card uses MPG4 compression on-board. It would not be able to capture AVI's or stream using this card (if I'm right). You could capture stills as long as the card uses WDM drivers.
        Bryan
          Using any card
          thas the plugin work with ati cards or only Hauppauge video cards
            It will work with any capture card that supports WDM drivers.
            Bryan
