Contacting HomeSeer This Week
See more
See less
Error when installing to HS2.2
  • Error when installing to HS2.2
    Hi,
    I downloaded the Hauppauge capture program and when it goes to install the update I get the following:
    1/19/2007 7:29:30 AM Updater Error Error installing file: RICHTX32.OCX , is file open?
    I have done the startup of HS after a fresh reboot but still get this message. Does the program work with HS2.2 or am I doing something wrong? I am using a DigiVue EDV-XV425 card for the video capture.
    The complete startup log for the Hauppauge capture program update is shown below:
    1/19/2007 7:29:00 AM Updater Starting installation of updates
    1/19/2007 7:29:00 AM Updater Applying update: Hauppauge Capture
    1/19/2007 7:29:01 AM Info Un-registering C:\Program Files\HomeSeer 2\hspi_Hauppauge_Capture.exe with Windows
    1/19/2007 7:29:03 AM Updater Copying file: C:\Program Files\HomeSeer 2\hspi_Hauppauge_Capture.exe
    1/19/2007 7:29:03 AM Info Registering C:\Program Files\HomeSeer 2\hspi_Hauppauge_Capture.exe with Windows
    1/19/2007 7:29:05 AM Info Un-registering C:\Program Files\HomeSeer 2\Bin\Hauppauge_Capture\CaptureUtility.exe with Windows
    1/19/2007 7:29:07 AM Updater Copying file: C:\Program Files\HomeSeer 2\Bin\Hauppauge_Capture\CaptureUtility.exe
    1/19/2007 7:29:07 AM Info Registering C:\Program Files\HomeSeer 2\Bin\Hauppauge_Capture\CaptureUtility.exe with Windows
    1/19/2007 7:29:09 AM Info Un-registering C:\Program Files\HomeSeer 2\Bin\Hauppauge_Capture\ImageUtility.exe with Windows
    1/19/2007 7:29:11 AM Updater Copying file: C:\Program Files\HomeSeer 2\Bin\Hauppauge_Capture\ImageUtility.exe
    1/19/2007 7:29:11 AM Info Registering C:\Program Files\HomeSeer 2\Bin\Hauppauge_Capture\ImageUtility.exe with Windows
    1/19/2007 7:29:13 AM Info Un-registering C:\Program Files\HomeSeer 2\Bin\Hauppauge_Capture\aspSleep.exe with Windows
    1/19/2007 7:29:15 AM Updater Copying file: C:\Program Files\HomeSeer 2\Bin\Hauppauge_Capture\aspSleep.exe
    1/19/2007 7:29:15 AM Info Registering C:\Program Files\HomeSeer 2\Bin\Hauppauge_Capture\aspSleep.exe with Windows
    1/19/2007 7:29:17 AM Info Un-registering C:\Program Files\HomeSeer 2\html\ThumbAsp\SImageUtil.dll with Windows
    1/19/2007 7:29:19 AM Updater Copying file: C:\Program Files\HomeSeer 2\html\ThumbAsp\SImageUtil.dll
    1/19/2007 7:29:19 AM Info Registering C:\Program Files\HomeSeer 2\html\ThumbAsp\SImageUtil.dll with Windows
    1/19/2007 7:29:21 AM Updater Copying file: C:\Program Files\HomeSeer 2\html\Camera.asp
    1/19/2007 7:29:21 AM Updater Copying file: C:\Program Files\HomeSeer 2\html\ThumbAsp\ListThumbs.asp
    1/19/2007 7:29:21 AM Updater Copying file: C:\Program Files\HomeSeer 2\html\ThumbAsp\ListThumbsInc.asp
    1/19/2007 7:29:21 AM Updater Copying file: C:\Program Files\HomeSeer 2\html\ThumbAsp\ListThumbsAVI.asp
    1/19/2007 7:29:21 AM Updater Copying file: C:\Program Files\HomeSeer 2\html\ThumbAsp\ListThumbsIncAVI.asp
    1/19/2007 7:29:21 AM Updater Copying file: C:\Program Files\HomeSeer 2\html\ThumbAsp\stringclass.asp
    1/19/2007 7:29:22 AM Updater Copying file: C:\Program Files\HomeSeer 2\html\ThumbAsp\centered.asp
    1/19/2007 7:29:22 AM Updater Copying file: C:\Program Files\HomeSeer 2\html\ThumbAsp\calendar.css
    1/19/2007 7:29:22 AM Updater Copying file: C:\Program Files\HomeSeer 2\html\images\calendar.gif
    1/19/2007 7:29:22 AM Updater Copying file: C:\Program Files\HomeSeer 2\html\images\down.gif
    1/19/2007 7:29:22 AM Updater Copying file: C:\Program Files\HomeSeer 2\html\images\up.gif
    1/19/2007 7:29:22 AM Updater Copying file: C:\Program Files\HomeSeer 2\html\images\NoThumb.gif
    1/19/2007 7:29:22 AM Updater Copying file: C:\Program Files\HomeSeer 2\html\javascript\simplecalendar.js
    1/19/2007 7:29:22 AM Info Un-registering C:\WINDOWS\system32\DBLIST32.OCX with Windows
    1/19/2007 7:29:24 AM Info Registering C:\WINDOWS\system32\DBLIST32.OCX with Windows
    1/19/2007 7:29:26 AM Info Un-registering C:\WINDOWS\system32\MSHFLXGD.OCX with Windows
    1/19/2007 7:29:28 AM Info Registering C:\WINDOWS\system32\MSHFLXGD.OCX with Windows
    1/19/2007 7:29:30 AM Updater Error Detailed error:
    1/19/2007 7:29:30 AM Updater Error Installation aborted, try restarting your computer and re-running the update.
    1/19/2007 7:29:30 AM Updater Error Installation of package Hauppauge Capture failed. Installation will be attempted the next time the application is started.
    1/19/2007 7:29:30 AM Updater Installation of updates completed, but one or more were unsuccessful and will be attemped again at the next restart.
    Any suggests on what I can try to get it to work?
    Bill
    There must be another window open already that is using that control. The simplest way I know of to get rid of that error is to edit the install.txt file in the hspi_Hauppauge_Capture.zip file and remove the line that contains RICHTX32.OCX. It will install without installing that file (since it is already installed)
    Bryan
    (Config is in my profile)
