A word of warning for Hauppauge Capture plugin users who also use the CM12/CM11 X10 interface....
Don't press the ENABLE/DISABLE button in the X10 column of the Hauppauge Capture plugin on the Setup->Interfaces screen. I did this thinking I was on a different line, and the ensuing problems took me an hour to track down.
The long and short of it is that if you do this, the following line of the HomeSeer settings.ini is modified to:
gSelectedx10Interface=Hauppauge Captu
However, when you want to go back to the CM12/CM11, because of a bug in HomeSeer(?), HomeSeer sets the line back to:
gSelectedx10Interface=X10 CM11A/CM1
instead of:
gSelectedx10Interface=X10 CM11A/CM12U
With this line incorrect, the CM12/CM11 plugin doesn't startup and you get the following error in the HS log:
05/11/2007 16:20:31 ~!~Error~!~Unable to initialize X-10 interface X10 CM11A/CM1 :Either no license or trial has expired
Just a word of warning in case anyone else falls into this trap. I have raised a helpticket on the assumption this is a HS bug.
(Out of interest Bryan, what does selecting this X10 button do in the Hauppauge Capture plugin?)
John
instead of:
John
