Contacting HomeSeer This Week
See more
See less
Setting up Hauppauge Capture with Hauppauge ImpactVCB card
  • Setting up Hauppauge Capture with Hauppauge ImpactVCB card
    Does anyone have simple instructions on how to setup the hauppauge capture plugin so I can get my cameras to work in HomeSeer 2.2. The instructions in the plug-in seem to be for the 1.x version of HomeSeer. Thanks.
    The instructions for setting up this plugin are essentially the same for HS V2.x ... the only difference is the screen shots for setting up HS devices are for the V1.1x of HS as are the screen shots of setting up events (if you want to use events).
    As far as providing simple instructions - that may be challenging. Setting up this plugin is more of an intermediate level rather than a beginner level. What part of the instructions are you having trouble understanding?
    Bryan
    (Config is in my profile)
      I installed the plug-in when when I try to change any settings in the config program I can not click the OK button. If I do click the OK button I see an error in the homesser log "Hauppauge Captu - An unexpected error occured in the cmdArray_Click(110) function/subroutine: [381 - Invalid property array index]" so I can not setup anything. I think i more than just a beginner but I figured that I must be doing something wrong.
        I'm having the same problems. The instructions are unclear on how to setup the camera and card. Every time, I'm getting the same errors.
        5/21/2008 4:47:57 PM - Hauppauge Captu - An unexpected error occured in the cmdArray_Click(110) function/subroutine: [381 - Invalid property array index]
        5/21/2008 4:32:58 PM - Hauppauge Captu - An unexpected error occured in the cbCameraSetting_Click(540) function/subroutine: [5 - Invalid procedure call or argument]
        5/21/2008 4:33:05 PM - Hauppauge Captu - An unexpected error occured in the cmdArray_Click(110) function/subroutine: [381 - Invalid property array index]
        5/21/2008 4:33:30 PM - Hauppauge Captu - An unexpected error occured in the cmdArray_Click(110) function/subroutine: [381 - Invalid property array index]
        5/21/2008 4:33:42 PM - Hauppauge Captu - An unexpected error occured in the tabCameras(180) function/subroutine: [381 - Subscript out of range.]
        5/21/2008 4:33:45 PM - Hauppauge Captu - An unexpected error occured in the tabCameras(180) function/subroutine: [381 - Subscript out of range.]
        5/21/2008 4:34:55 PM - Hauppauge Captu - An unexpected error occured in the cmdArray_Click(110) function/subroutine: [381 - Invalid property array index]
        5/21/2008 4:35:26 PM - Hauppauge Captu - An unexpected error occured in the tabCameras(180) function/subroutine: [381 - Subscript out of range.]
        5/21/2008 4:35:36 PM - Hauppauge Captu - An unexpected error occured in the cmdArray_Click(1650) function/subroutine: [5 - Invalid procedure call or argument]
        5/21/2008 4:36:16 PM - Hauppauge Captu - An unexpected error occured in the cmdArray_Click(110) function/subroutine: [381 - Invalid property array index]
        5/21/2008 4:36:45 PM - Hauppauge Captu - An unexpected error occured in the cmdArray_Click(110) function/subroutine: [381 - Invalid property array index]
