Contacting HomeSeer This Week
See more
See less
Accessing streaming camera image
  • Accessing streaming camera image
    I am trying to access my cameras through MainLobby. I have the streaming set to port 2407. This works fine when I navigate through the homeseer menus to the Stream option. However, I just get blank screens when I access http://mypc:2407. I have tried this using the internal IP address and external host name (trying to eliminate the firewall which does have 2407 forwarded). What do I have to put into the browser to go straight to the streaming image? Thanks.
    I am guessing you are trying to stream the video from another source (not ML) eh?
    I believe...and its been a while but you will need to set up a reverse proxy or stream it from the source to see your video outside of your network. IE: set up your firewall to pass your video stream outside of your home network.
    Another thing you could try is installing a network camera capture program on your ML server which will live capture/stream network video. This way the source video IP would be the same as your ML server IP?
    - Pete
    Auto mator
    HS4 pro - 4.0.3.0 - Ubuntu 18.04/W7e 64 bit Intel Kaby Lake CPU - 32Gb - Mono 6.8X
      I can access my homeseer web site just fine inside and outside the home. I have port 2407 forwarded to the homeseer server. This doesn't explain why I can't access the streaming video from within the home using internal ids?
      For example, my homeseer server is 192.168.1.155
      Shouldn't I be able to see the streaming video on:
      http://192.168.1.155:2407?
      When I plug this URL into Windows Media Player it works fine - but I get nothing when I plug this into IE.
      Obviously I am missing some required syntax to display the video window on an IE page.
        So is your video source the same IP as your HS or ML Box or is it a different IP?
        - Pete
        Auto mator
          It is the same IP.
            If you can see it with WMP then your should also see it in IE. Does it show a box or give you a codec error? Try running same with Firefox.
            - Pete
            Auto mator
              This does not work because the URL you are giving IE is a streaming address - not a web page. If you direct ML to a web page containing the Media Player ActiveX control that directs the stream to "http://192.168.1.155:2407?" it will work.
              Bryan
              (Config is in my profile)
