Having just moved HS over to HS pro and also onto a new Atom machine (which has the same hardware as the old hs xp machine) and now running Windoze 7 pro. Hauppauge capture is the only plugin not working.
Anyone know if this works under win 7 ?
Capture works but the capconfig screen won't load, it just gives the message capconfig terminated in the log straight away .
Any ideas? or is it time to move onto a better capture plugin?
Cheers
Cheers
