Contacting HomeSeer This Week
See more
See less
Is this still supported
  • Is this still supported
    I am getting errors when starting up this plugin and I wonder if it is still supported
    Kirk
    http://cleverhouseautomation.ca
    http://southcoastwebsitedesign.ca
    Are you using Windows 7 by any chance? Did just do a new install? If so did you install the VB6 runtime? What version of HS are you running?
    Sorry for all the questions but I do support the plugin as bet I can. My development PC is down and I haven't had a chance to get it fixed yet.
    Bryan
    (Config is in my profile)
      Hello,
      Yes it is a new install on an XP box. What vb6 runtime needs to be installed? I see something about Media encoder and Direct X, but nothing about vb6.
      Kirk
        Yes VB6 runtime is also required. There is a download link here: http://support.microsoft.com/kb/290887
        Bryan
          Ok. I did not realize that. Thanks
          Kirk
            Also having problems
            I am seeing these errors when the plugintrys to run:
            <TABLE border=0 cellSpacing=2 cellPadding=0 width="100%"><TBODY><TR><TD class=LOGDateTime0 noWrap align=left>1/12/2013 5:19:17 PM </TD><TD class=LOGType0 colSpan=3 align=left>Hauppauge Capture Error </TD><TD class=LOGEntry0 colSpan=8 align=left>An unexpected error occured in the initVideoSettings(30) function/subroutine: [429 - ActiveX component can't create object]</TD></TR><TR><TD class=LOGDateTime1 noWrap align=left>1/12/2013 5:19:17 PM </TD><TD class=LOGType1 colSpan=3 align=left>Hauppauge Capture Error </TD><TD class=LOGEntry1 colSpan=8 align=left>Hauppauge Capture plugin did not detect any installed capture cards</TD></TR><TR><TD class=LOGDateTime0 noWrap align=left>1/12/2013 5:19:17 PM </TD><TD class=LOGType0 colSpan=3 align=left>Hauppauge Capture Error </TD><TD class=LOGEntry0 colSpan=8 align=left>An unexpected error occured in the InitHW(480) function/subroutine: [9 - Subscript out of range]</TD></TR></TBODY></TABLE>
            So far I have made sure I have installed VB6 Runtime, DirectX 9C, current drivers for my Hauppague WinTV 38101, and Windows Media Encoder. I am able to see the video when I run Media Encoder so I know the card is working. Windows XP Pro with HomeSeer Pro version 2.5.0.55. Any hints or help would be appreciated.
              It sounds like the VideoCapX activeX control is not registered.
              Try these steps:
              1 First search for the file VideoCapX.ocx and use that folder for step 4
              2 Shut down HomeSeer
              3 Open a DOS windows
              4 Get into the directory from step 1
              5 Type in regsvr32.exe -u videocapx.ocx
              6 You should get a popup that says unregister successful
              7 Type in regsvr32.exe videocapx.ocx
              8 You should get a popup that says register successful
              Bryan
                Try these steps:
                I found two copies of videocapx.ocx in these directories:
                C:\Program Files\HomeSeer HSPRO\Bin\Hauppauge_Capture
                C:\Program Files\HomeSeer HSPRO\Updates2\Hauppauge Capture4.1.0.2
                Both have the same file with the same size and date:
                12/13/2004 09:00 PM 679,936 videocapx.ocx
                I tried all 8 steps on the file in the first path and recieved the same errors in the log. Tried again with the file in the second directory and again teh same error. Just to confirm, videocapx.ocx did unregister and register each time.
                Here are the new errors in case there is anything else you can gleen from them:
                1/14/2013 8:45:50 PM - Hauppauge Capture - An unexpected error occured in the initVideoSettings(30) function/subroutine: [429 - ActiveX component can't create object]
                1/14/2013 8:45:50 PM - Hauppauge Capture - Hauppauge Capture plugin did not detect any installed capture cards
                1/14/2013 8:45:50 PM - Hauppauge Capture - An unexpected error occured in the InitHW(480) function/subroutine: [9 - Subscript out of range]
                Is there a way to uninstall the plugin then reinstall it?
                Thanks in advance for any more help you can provide.
                Rod
                  I couldn't find an uninstall for the Hauppague plugin so I tried a fresh install and received similar results. Here are the steps:
                  1. Shutdown HS Pro
                  2. Copy C:\Program Files\HomeSeer HSPRO to a temporary directory.
                  3. Uninstall HS Pro.
                  4. Install a fresh copy of HS Pro
                  5. Use USE HS Pro updater to install Hauppague plugin (also installed UltraM1G plugin).
                  Below is a copy of the log:
                  1/15/2013 12:59:29 PM Startup Settings Loaded.
                  1/15/2013 12:59:29 PM Startup Current sunrise/sunset values calculated.
                  1/15/2013 12:59:29 PM Startup HSPhone external interface class started.
                  1/15/2013 12:59:29 PM Startup Local voice recognition class started.
                  1/15/2013 12:59:29 PM Startup Database SAVE process started.
                  1/15/2013 12:59:29 PM Startup Loading configuration file ...
                  1/15/2013 12:59:29 PM System Loading device types file...
                  1/15/2013 12:59:29 PM Database Opening (Mode=Read) up HomeSeer database: C:\Program Files\HomeSeer HSPRO\config\sample.mdb
                  1/15/2013 12:59:30 PM Database Loading Devices...
                  1/15/2013 12:59:30 PM Load Config 3 total devices loaded.
                  1/15/2013 12:59:30 PM Load Config Checking device type settings for all devices...
                  1/15/2013 12:59:30 PM Load Config Finished checking device type settings.
                  1/15/2013 12:59:30 PM Load Config Loading Events...
                  1/15/2013 12:59:30 PM Load Config 6 total events loaded.
                  1/15/2013 12:59:30 PM Database HomeSeer configuration database C:\Program Files\HomeSeer HSPRO\config\sample.mdb has been closed.
                  1/15/2013 12:59:30 PM Startup HomeSeer version is: 2.5.0.49
                  1/15/2013 12:59:30 PM Startup Starting remoting (Remote client connection monitor)
                  1/15/2013 12:59:30 PM Startup Creating Speaker Client Interface Object...
                  1/15/2013 12:59:30 PM Startup Initializing phone interface...
                  1/15/2013 12:59:30 PM HSPhone HomeSeer Phone Web Interface initializing.
                  1/15/2013 12:59:30 PM Startup Checking for pending updates to be installed...
                  1/15/2013 12:59:30 PM Startup Restoring Device Status...
                  1/15/2013 12:59:31 PM Startup Checking for available plug-ins
                  1/15/2013 12:59:31 PM Plug-In Found plug-in: X10 CM11A/CM12U, version: 1.0.1.0
                  1/15/2013 12:59:31 PM Plug-In Found plug-in: X10 CM15AUSB, version: 1.0.0.3
                  1/15/2013 12:59:31 PM Plug-In Found plug-in: Hauppauge Capture, version: 4.1.0.2
                  1/15/2013 12:59:31 PM Plug-In Found plug-in: HSTouch Server, version: 1.0.0.45
                  1/15/2013 12:59:31 PM Plug-In Found plug-in: HSTouch Android, version: 1.0.0.0
                  1/15/2013 12:59:31 PM Plug-In Found plug-in: HSTouch iPhone, version: 1.0.0.0
                  1/15/2013 12:59:31 PM Plug-In Found plug-in: Insteon, version: 1.1.52.1
                  1/15/2013 12:59:31 PM Plug-In Found plug-in: iTunes, version: 2.5.0.13
                  1/15/2013 12:59:31 PM Plug-In Found plug-in: Media Player, version: 2.5.0.16
                  1/15/2013 12:59:31 PM Plug-In Found plug-in: UltraM1G, version: 1.1.4699.35853
                  1/15/2013 12:59:31 PM Plug-In Found plug-in: UPB, version: 1.0.2.7
                  1/15/2013 12:59:32 PM Startup Initializing Plug-Ins
                  1/15/2013 12:59:32 PM Plug-In Interface UltraM1G is running as a trial, 30 days remaining.
                  1/15/2013 12:59:32 PM UltraM1G Info UltraM1G version 1.1.4699.35853 starting ...
                  1/15/2013 12:59:32 PM Plug-In Initializing Plug-in: UltraM1G
                  1/15/2013 12:59:32 PM UltraM1G Info UltraM1G - initializing I/O ...
                  1/15/2013 12:59:32 PM UltraM1G Warning Elk M1 interface is disabled.
                  1/15/2013 12:59:32 PM Error Initializing interface: UltraM1G-Unable to initialize Elk M1 Hardware :Elk M1 interface is disabled.
                  1/15/2013 12:59:32 PM Plug-In Finished initializing plug-in UltraM1G
                  1/15/2013 12:59:32 PM Plug-In Interface Hauppauge Capture is running as a trial, 30 days remaining.
                  1/15/2013 12:59:32 PM Plug-In Initializing Plug-in: Hauppauge Capture
                  1/15/2013 12:59:32 PM Hauppauge Capture Info HSPI_HAUPPAUGE_CAPTURE - register callback complete.
                  1/15/2013 12:59:32 PM COM Plugin Calling InitIO
                  1/15/2013 12:59:32 PM Hauppauge Capture Info HSPI_HAUPPAUGE_CAPTURE Version: 4.1.2 - initializing I/O
                  1/15/2013 12:59:33 PM Hauppauge Capture Info Registering menu items
                  1/15/2013 12:59:33 PM Hauppauge Capture Error An unexpected error occured in the initVideoSettings(30) function/subroutine: [429 - ActiveX component can't create object]
                  1/15/2013 12:59:33 PM Hauppauge Capture Error Hauppauge Capture plugin did not detect any installed capture cards
                  1/15/2013 12:59:33 PM Hauppauge Capture Error An unexpected error occured in the InitHW(480) function/subroutine: [9 - Subscript out of range]
                  1/15/2013 12:59:33 PM Plug-In Finished initializing plug-in Hauppauge Capture
                  1/15/2013 12:59:33 PM Plug-In Finished initializing X10 interface
                  1/15/2013 12:59:33 PM Plug-In Finished initializing infrared interface
                  1/15/2013 12:59:33 PM Web Server Local IP address (subnet) is: XXX.XXX.XXX.XXX (255.255.255.0)
                  1/15/2013 12:59:33 PM Web Server Web Server started on port 80
                  1/15/2013 12:59:33 PM Web Server UPNP Discovery started
                  1/15/2013 12:59:33 PM Startup Creating ASP.NET application host...
                  1/15/2013 12:59:35 PM Startup ASP.NET application host created
                  1/15/2013 12:59:35 PM Startup Start automation engine...
                  1/15/2013 12:59:35 PM Startup This version of HomeSeer is not registered and is running as a trial, 30 days remaining.
                  1/15/2013 12:59:35 PM Startup Initializing Speaker Client Interface
                  1/15/2013 12:59:35 PM Speech Listening for remote speaker connections on port 8742
                  1/15/2013 12:59:35 PM Startup HS2Sentry is disabled in Setup, sentry will not be started.
                  1/15/2013 12:59:35 PM Startup Starting Event Scheduler...
                  1/15/2013 12:59:35 PM Startup Checking HTTP connection...
                  1/15/2013 12:59:35 PM Web Server Web Server authorized local login successful from: 127.0.0.1 User: default
                  1/15/2013 12:59:35 PM Startup Updater services starting...
                  1/15/2013 12:59:35 PM Startup Starting DDNS service...
                  1/15/2013 12:59:35 PM Startup Running the Startup.txt Script
                  1/15/2013 12:59:36 PM Startup Scripting is OK and is now running Startup.txt
                  1/15/2013 12:59:36 PM Startup Start up complete.
                  1/15/2013 12:59:38 PM Web Server Web Server authorized local login successful from: 192.168.0.152 User: default
                  1/15/2013 12:59:38 PM Network Speaker client connected from: 127.0.0.1
                  1/15/2013 12:59:39 PM Speaker Speaker host added, Name: hsp IP address: 127.0.0.1
                  1/15/2013 1:00:37 PM Hauppauge Capture Debug Level 2 Request to show CapConfig Received
                  1/15/2013 1:00:37 PM Hauppauge Capture Error An unexpected error occured in the Form_Load(70) function/subroutine: [9 - Subscript out of range]
                  The last part of the log is where I try to configure the Hauppague plugin. The configuration menu did not find the card.
                  Other details that may help:
                  Software:
                  -OS = Windows XP Pro SP2
                  -HSPro version 2.5.0.55
                  -WebcamXP Free v5.5.1.5 Build 33554
                  -ffdshow-20041012
                  -Windows Media Encoder 9 is currently uninstalled.
                  Hardware:
                  - Dell Pentium 4 -2.8Ghz w/ 2GB RAM
                  - Hauppague WinTV 38101 Rev B410 PCI video capture card (878/9 WDM Aux Driver 1/25/2006 v3.49.24025.0)
                    I have not been able to get rid of errors in logs. Most things work but still errors:
                    24/01/2013 2:04:42 PM Hauppauge Capture Error An unexpected error occured in the UpdateCameraZoneAssignments(210) function/subroutine: [13 - Type mismatch]
                    24/01/2013 2:11:07 PM Hauppauge Capture Error An unexpected error occured in the SetCamera(gbNINJA) function/subroutine: [13 - Type mismatch]
                    24/01/2013 2:11:25 PM Hauppauge Capture Error An unexpected error occured in the cbCameraSetting_Click(70) function/subroutine: [380 - Invalid property value]
                    24/01/2013 2:11:30 PM Hauppauge Capture Error An unexpected error occured in the cbCameraSetting_Click(70) function/subroutine: [380 - Invalid property value]
                    24/01/2013 2:12:29 PM Hauppauge Capture Error An unexpected error occured in the SetCamera(gbNINJA) function/subroutine: [13 - Type mismatch]
                    24/01/2013 2:12:57 PM Web Server Web Server authorized login successful from: 96.63.29.123 User: kirkneuert
                    24/01/2013 2:13:16 PM Hauppauge Capture Error An unexpected error occured in the cbCameraSetting_Click(70) function/subroutine: [380 - Invalid property value]
                    24/01/2013 2:13:23 PM Hauppauge Capture Error An unexpected error occured in the cbCameraSetting_Click(70) function/subroutine: [380 - Invalid property value]
                    24/01/2013 2:16:17 PM Device Control Device: Hauppauge Capture Main Alarm (_1) Value set to 0
                    24/01/2013 2:16:19 PM Device Control Device: Hauppauge Capture Front Porch Motion Alarm (_2) Value set to 0
                    24/01/2013 2:16:50 PM Hauppauge Capture Error An unexpected error occured in the cbCameraSetting_Click(70) function/subroutine: [380 - Invalid property value]
                    24/01/2013 2:18:00 PM Hauppauge Capture Error An unexpected error occured in the UpdateCameraZoneAssignments(210) function/subroutine: [13 - Type mismatch
                    I get these when ever I open the config.
                    When the system is armed I get:
                    24/01/2013 1:55:47 PM Hauppauge Capture Error An unexpected error occured in the SetCamera(gbNINJA) function/subroutine: [13 - Type mismatch]
                    24/01/2013 1:55:53 PM Hauppauge Capture Error An unexpected error occured in the SetCamera(gbNINJA) function/subroutine: [13 - Type mismatch]
                    24/01/2013 1:56:07 PM Hauppauge Capture Error An unexpected error occured in the SetCamera(gbNINJA) function/subroutine: [13 - Type mismatch]
                    24/01/2013 1:58:50 PM Hauppauge Capture Error An unexpected error occured in the SetCamera(gbNINJA) function/subroutine: [13 - Type mismatch]
                    24/01/2013 1:59:07 PM Hauppauge Capture Error An unexpected error occured in the SetCamera(gbNINJA) function/subroutine: [13 - Type mismatch]
                    Kirk
                      I haven't had much luck in getting dev PC running. Can you send me a copy of the hspi_Hauppauge_Capture.ini file?
                      Bryan
                        Here it is
                        Sorry, missed this coming in.
                        Here is my ini file
                        Kirk
                          Any ideas?
                          Kirk
                            There is a [CameraSettings] section in the ini file but there isn't any camera's listed. Do your camera's have the device type set to "xm14a (Ninja X10 Camera)"? There might be a setting for the camera that has been missed. Do you have the camera's assigned to the montion sensors?
                            Sorry about taking so long to get back top you - we were in Jamaica for the last 2 weeks.
                            Bryan
