Thank you to all who were willing to try out the first release of the MobiLinc plug-in.
What's new in 0.5.2:
- UDP Auto-discovery in Windows XP is now disabled which was causing the crash on Windows XP machines in the 0.5.1 release. In the meantime a solution to the problem is being investigated.
UDP is used by the plug-in and HS MobiLinc to determine if HS MobiLinc is connected to a local WiFi source. This aides HS MobiLinc in Auto detect connection mode if it should connect over HTTP or HTTPS. For Windows XP users, please download 0.5.2 and set your Connect Method under HS MobiLinc settings to HTTP or HTTPS. Auto will still work, but will default to HTTPS if both HTTP and HTTPS fields are filled out.
UDP Auto-discovery is still enabled and working for Windows Vista and Windows 7.
