I'm running Windows 7 and HS2, I've downloaded the HS Mobilinc plug-in several times however, when I restart HS to install the plug-in, Mobilinc isn't there. Any help would be greatly appreciated...Thanks.
If this is your first visit, be sure to check out the FAQ. You must register before you can post.
IMPORTANT: Your first post will be checked for appropriate content. This may take a bit of time.
