Contacting HomeSeer This Week
See more
See less
Error - Need help!
  • Error - Need help!
    I am getting an error message on HSDroid whenever i try to open a device, i get the message: "Server Access failed with: null" on my galaxy nexus running android 4.0.4... I know i am connected to the server because it can see my devices and events, but i cannot open/start them. Here is my log file when attempting to turn on a lamp:
    6/19/2012 12:22:07 PM ~!~Web Server~!~Web Server authorized login successful from: xxx.xxx.xx.xx(i hide this for good measure, but it is my correct ip) User: admin
    6/19/2012 12:22:07 PM ~!~HSDroid~!~link = /hsdroid2?cmd=GetCaps2
    6/19/2012 12:22:07 PM ~!~HSDroid~!~cmd = cmd value = GetCaps2
    6/19/2012 12:22:07 PM ~!~HSDroid~!~No Music API found
    6/19/2012 12:22:07 PM ~!~HSDroid~!~HSTouch Server: caps = 4
    6/19/2012 12:22:07 PM ~!~HSDroid~!~HSTouch iPhone: caps = 4
    6/19/2012 12:22:07 PM ~!~HSDroid~!~HSTouch Android: caps = 4
    6/19/2012 12:22:07 PM ~!~HSDroid~!~HSTouch Server Unlimited: caps = 4
    6/19/2012 12:22:07 PM ~!~HSDroid~!~SqueezeBox: caps = 38
    6/19/2012 12:22:07 PM ~!~HSDroid~!~HSDroid: caps = 4
    6/19/2012 12:22:07 PM ~!~HSDroid~!~GetCaps2 returned False False False 1.06
    6/19/2012 12:23:28 PM ~!~HSDroid~!~link = /hsdroid2?cmd=GetLocations
    6/19/2012 12:23:28 PM ~!~HSDroid~!~cmd = cmd value = GetLocations
    6/19/2012 12:23:28 PM ~!~HSDroid~!~Processing device Bedroom:Wills Lamp, code = Q5
    6/19/2012 12:23:28 PM ~!~HSDroid~!~Processing device Bedroom:Vals Lamp, code = Q6
    6/19/2012 12:23:28 PM ~!~HSDroid~!~Processing device Living Room:Living Room Motion Sensor, code = Q4
    6/19/2012 12:23:28 PM ~!~HSDroid~!~Processing device Living Room:Laser Show, code = Q1
    6/19/2012 12:23:28 PM ~!~HSDroid~!~Processing device Living Room:Living Room Motion Sensor Battery, code = Q3
    6/19/2012 12:23:28 PM ~!~HSDroid~!~Processing device Living Room:Living Room Motion Sensor Root, code = Q2
    6/19/2012 12:23:28 PM ~!~HSDroid~!~Processing device SqueezeBox:Status, code = [1
    6/19/2012 12:23:28 PM ~!~HSDroid~!~Processing device SqueezeBox:Player 1 Title, code = [7
    6/19/2012 12:23:28 PM ~!~HSDroid~!~Processing device SqueezeBox:Player 1 Status, code = [5
    6/19/2012 12:23:28 PM ~!~HSDroid~!~Processing device SqueezeBox:Player 1 Shuffle and Repeat, code = [8
    6/19/2012 12:23:28 PM ~!~HSDroid~!~Processing device SqueezeBox:Player 1 Volume, code = [6
    6/19/2012 12:23:28 PM ~!~HSDroid~!~Processing device SqueezeBox:Library Statistics, code = [3
    6/19/2012 12:23:28 PM ~!~HSDroid~!~Processing device SqueezeBox:Player 1 Speak Volume, code = [9
    6/19/2012 12:23:28 PM ~!~HSDroid~!~Processing device SqueezeBox:Player 1 Name, code = [4
    6/19/2012 12:23:28 PM ~!~HSDroid~!~Processing device SqueezeBox:Player Count, code = [2
    6/19/2012 12:23:28 PM ~!~HSDroid~!~Processing device SqueezeBox:Player 1 Alarm 1, code = [10
    6/19/2012 12:23:28 PM ~!~HSDroid~!~Processing device SqueezeBox:Player 1 Alarm 2, code = [11
    6/19/2012 12:23:28 PM ~!~HSDroid~!~Adding location Bedroom
    6/19/2012 12:23:28 PM ~!~HSDroid~!~Adding location Living Room
    6/19/2012 12:23:28 PM ~!~HSDroid~!~Adding location SqueezeBox
    6/19/2012 12:23:31 PM ~!~HSDroid~!~link = /hsdroid2?cmd=GetDevicesForLocation&Location=Bedroom
    6/19/2012 12:23:31 PM ~!~HSDroid~!~cmd = cmd value = GetDevicesForLocation
    6/19/2012 12:23:31 PM ~!~HSDroid~!~cmd = Location value = Bedroom
    Any ideas? I am using port 81 for homeseer.
    Go into Preferences->Logging preferences on HSDroid on your phone, then set the logging level to verbose. Then exit HSDroid, start it back up, try to turn something on, then go to Log->Email Log and email me the log and I'll see if I can tell what's going on.
    Dan
      I am seeing these errors as well on my Droid Bionic running 4.0.4 as well. My kicker is that when my phone is on wifi it works fine, but gives these errors when on 4G/3G.
        OK, this appears to be fixed now. They'll be a new version on Google Play whenever it propogates, or you can download it directly from http://www.danhinsley.com/downloads/HSDroid.apk.
        Let me know if there are any other problems.
        Dan
