Hi,
I've been using hsGirder and Netremote for about a year and a half now and once I got it up and running, I haven't had to mess with it at all until now. I've had Homeseer and hsGirder running for over 2 months without a restart and then just recently, I had to restart. After I restarted, I lost my hsGirder.
When I select a button from my netremote interface, I'm not getting anything.. anything even with the debug level set to 3.
Jeez!!! When I went to confirm that, it worked. This hasn't worked for 3 days. I've been trying to diagnose this for 3 days now and the moment I put my problem on the boards, it decides to work. I've changed nothing.
hsGirder version: 0.9.0.7
HomeSeer version is: 2.0.1997.0
I have some logs attached.
hsGirder_Error_log.txt - Is what my Homeseer looks like when it's booting up. Although there are other errors, I keep getting the 'Response: Girder is not running, event was not triggered'. I don't know why I'm getting this. And I don't remember seeing this before. I also don't usually have my debug level set to 3 either.
really_confused_log.txt - Is the log I just got when things started to magically work. I still see the 'Response: Girder is not running, event was not triggered'. Any reason why I'm getting this? I don't have Girder running on my Homeseer machine but I do have hsGirder running. I do have Girder running on another maching called 'video' in which I'm calling through a script called nrMM.txt.
Any help would be appreciated. I don't want to start tearing things apart unless I really have to.
Eric
Eric
