Need help getting this going
This topic is closed.
    I am struggling with getting this plug-in going. I can't seem to get the HS Connection to be set. Homeseer and Sage are on the same server.
    Homeseer reports- 8/31/2010 9:48:20 PM - InControl_Sage - ERROR - Sage host not responding (192.168.x.x)
    Have run across things to check in the forums but still can't get it talking. Hoping to get some pre-sales support here.
    You have upgraded to the latest version?
      SageTV 7.0.15.237
      Sage Homeseer Plugin 1.31
      Homeseer 2.4.0.11
        And have you opened the ports? (10900-1900x)
          no firewall & Sage is installed on the HS server
            What I did to get it to work was to stop HS and the SageTV service, remove all settings (delete the hspi_incontro.ini from the HS/Config directory and delete all lines starting with "lamanmi" in the .properties files in the SageTV directory).
            Started the SageTV service and HomeSeer and suddenly everything worked.
              I don't run either as a service but tried shutting both programs down and doing as you suggested. Still no luck.
                Was able to get a little further by modifying the hspi_inControl.ini file. Now can't seem to get past the ID/Password validation.
                  mhog,
                  For user id and password, be sure that is set up as a web user in HomeSeer. Also to see if HomeSeer is getting an ID password:
                  - Change the HomeSeer InControl log settings to 4
                  - Go to Sage and the InControl Options in sage and click "Click to Login"
                  - Then see if the HomeSeer log has your user id and password (note password is "*", but be sure the number of "*" is the number of characters in your password).
                  For your initial issue, some other questions:
                  - Does your server have a fixed or dynamic IP address?
                  -When you entered the HomeSeer IP/Name in Sage did you enter an ip address or computer name?
                  - Did Sage complete the configuration at one point?
                  You can also try in Sage to use "localhost" as the HomeSeer IP/Name in Sage.
                  If you still have issues, it would be helpful if you can follow the process below:
                  - Turn on logging in InControl on HomeSeer to 4
                  - Enable Sage TV Debug logging
                  - Fully exit Sage and then HomeSeer
                  - Start HomeSeer and then Start Sage
                  - In Sage go to the Control option
                  - Send me both the Homeseer and Sage log files.
                  Michael
                    Sorry Michael, I just plain ran out of time to mess with this. Now getting back to it both I see that both trials have expired. I will just try again someday when things are stable. Thanks for trying to help me out.
