This is a continuation of earlier thread at
Prior Features and Problems Discussions
I will attempt to maintain a log of new feature requests and reported problems with mcsAudrey in this thread. Feel free to post in this thread or any other in the mcsAudrey forum and I will provide the feedback in this thread as to the status.
Version of mcsAudrey between releases to the updater will also be mainted here. It is generally my intent to provide lastest fixes and new feature evalutions here to allow them to mature a little before putting them on the updater.
<pre class="ip-ubbcode-code-pre">
PR1 1.2.0 Object error when starting mcsAudrey after initial install
PR2 1.1.0 Provide slideshow control per Audrey
PR3 1.6.0 Enhance slideshow options
PR4 1.2.0 Merge AudreyServer source into mcsAudrey
PR5 1.2.1 Overflow on slideshow
PR6 1.3.1 Script & GUI interface provides no response
PR7 Add database support for Audrey Statistics
PR8 1.3.0 Add provisions for delays after UDP commands
PR9 1.3.0 Add ability to control LEDs based on motion
PR10 1.3.0 MakeDevice type mismatch error
PR11 1.3.0 Check UDP client connection and use TCP/IP if not present
PR12 1.3.0 Initialize Audrey to homeseer state on HS restart
PR13 1.3.1 Only 2 Timers allocated
PR14 1.3.0 Message box on hs shutdown about server disappeared
PR15 1.4.0 Error generated in hwinit when hsp not installed
PR16 1.4.0 Sounds device updated when sounds volume changed
PR17 1.4.0 Add CID event support
PR18 1.5.0 Add serial CID event support
PR19 1.4.1 Wrap HTML around only slideshow exit files staring with "links"
PR20 1.5.0 Separate link and slideshow exit filenames
PR21 1.5.0 Support Sound & Text & ACID response to CID events
PR22 1.6.0 Only lower case image file names recognized on slideshow
PR23 1.6.0 Add debug for slideshow filelist and current selection
PR24 1.6.0 Add sequential vs random slide selection
PR25 1.6.0 Add selection for power cycle off time
PR26 1.6.1 Scale vertical or horizontal based upon slide image size
PR27 1.6.2 Incorrect handling of meta statement in HTML files
PR28 1.6.2 Check for zero value for update interval on slideshow
PR29 1.6.3 Division by Zero error if no slide group slides specified
PR30 1.6.4 Version compatibility problems with hs beyond 1.6.99
PR31 1.6.5 Provide visibility to Audrey Message Queue
PR32 1.7.1 Send "awake" command after AudreySendCID
PR33 1.8.0 Add PowerCycle control to Sleep/Awake device
PR34 1.8.0 Modem CID should not wait for NAME
PR35 1.8.1 Power cycle occurs on hs restart if PowerCycle was last commmand given
PR36 1.8.4 Error message after power-cycle sleep control used
PR37 1.8.6 CID modem may not deliver NMBR (only name)
PR38 1.9.0 Slide groups not cycling properly
PR39 1.9.0 Allow use of computer name rather than IP
PR40 1.9.1 Some commmands sent TCP rather than UDP
PR41 1.9.2 Awaken Audrey on CID event if CID routed there
PR42 1.9.3 Filter [ and ] house codes in ini file
PR42 1.9.4 Allow exit pages from slideshow
PR43 1.10.0 Audrey always goes to sleep
PR44 1.10.0 Add User controls for Text formats
PR45 1.10.1 Script-based speaking stopped
PR46 1.11.0 Support for 9 Audrey's
PR47 1.10.2 CID not delivered to ACID from hsp
PR48 1.11.0 Wav files from non-HTML directory dont work
PR49 1.11.0 HSP object may be initialized before HSP has loaded.
PR50 1.12.1 Play HSP Announcement message if available
PR51 1.12.1 Init string not sent to modem for serial CID
PR52 1.12.1 Allow use of HSP address book when using serial CID
PR53 1.13.0 Allow user-selection of the image server for slideshow
PR54 1.13.0 Add Date/Time to CID text pushed to Audrey
PR55 1.13.1 Sound byte volume string missing %
PR56 1.13.1 Incomplete processing of CID for non-ACID delivery
PR57 1.13.2 Reorganize CID Setup Tab
PR58 1.14.0 Sound Byte volume not correct from GUI
PR59 1.14.0 Add CID device with option to trigger CID event
PR60 1.15.1 Landscape oriented slides cause slideshow scroll bars
PR61 1.16.0 Add NetCallerID Support (Krumpy's changes)
PR62 1.16.0 Allow older IE Browser compatibility
PR63 1.16.0 Add Friends.txt Phonebook lookup
PR64 1.16.1 Power cycle attempted even when no power control device exists
PR65 1.16.2 CID spoken response sometimes times-out
PR66 1.16.2 ProcessModemInput debug statement in log
PR67 1.16.2 Multiple screen-on commands given for CID wakeup
PR68 1.16.5 Add CID Sentry as possible CID client
PR69 1.16.6 Subscript range error on startup
PR70 1.16.10 CID out of sync with NMBR NAME sequence
PR71 1.16.11 Some CID calls missed
PR72 1.17.2 Power cycle occurs at wrong hours
PR73 1.17.2 Add XAP support
PR74 1.18.0 Add option to exclude HSP location on CID
PR75 1.19.0 Allow Audrey devices to be status only
PR76 1.20.0 Add Option to control CID termination
PR77 1.20.2 Power cycle recovery ignores setup to disable it
PR78 1.20.3 Test Message in V1.20.2
PR79 1.21.0 Resize slideshow file size so audrey does not stick on X
PR80 1.21.0 Add internal server for slideshow to avoid HS server lockups
PR81 1.21.0 Add power-cycle logic per sbessel's approach
PR82 1.21.3 IP not detected correctly on internal server
PR83 1.21.4 Internal server post data not recognized
PR84 1.21.5 External server selection does not stick
PR85 1.21.6 Async Call Automation error
PR86 1.21.7 High CPU Utilization on 1.21.6
PR87 1.21.7 Keep Audrey awake on slideshow if no motion detector
PR88 1.21.9 Timer object error on power cycle
PR89 1.21.10 Change CID phonebook source from AT to FROM
PR90 1.21.10 remove /kojak/ from power up file match
PR91 1.21.11 wav files are not served by internal server
PR92 1.21.12 xap updates to allow execution as standalone node
PR93 1.21.13 IE Timeout timer not created
PR94 1.22.0 HS2 Compatibility
PR95 1.23.0 Additional HS2 evolution
PR96 1.23.1 Added Debug to availability of HSP object
--------- Above in Updater -------
PR97 1.23.3 NewDevice error in HS2
PR98 1.23.5 NewDevice created with invalid HC/DC in HS2
PR99 1.23.5 AudreyServer does not work in HS2
PR100 1.23.8 Correct reference to HSP in HS2
PR101 1.23.10 Different attempt at HSP definition
PR102 1.23.10 Added limit of 20 command queue depth before power cycle
PR103 1.23.13 HS 1955 compatibility
PR104 1.23.29 Make TTS voice a selector rather than text box
PR105 1.23.29 Allow scriptable INI setting to change voice dynamically
PR106 1.23.29 Alter tab order for Audrey IP setup
PR107 1.23.32 Save Voice does not show on voice selector
PR108 1.23.37 Bypass HS2 SpeakToFile to allow selected voice on HS2
PR109 1.24.0 Add "Ex" methods to allow single line script commands in events
Pr110 1.24.5 Update to current compile
PR111 1.24.6 Additional debug in ButtonPress function
PR112 1.24.8 Update to HS2 SDK for device property for SETIO on value change
------ above in updater -----------
PR113 1.24.28 House Codes deletion/number problems with HS2
PR114 1.24.36 Continuous SpeakToFile Error
PR115 1.24.38 Multi-step error on save (HS2 .misc property incompatibilty)
PR116 1.25.0 Add Log CID to HS Log option
------ removed from updater ------
PR117 1.26.4 misc property upper bits set on conversion to .NET
PR118 1.26.7 AudreySpeakEX always speaks Zero
PR119 1.28.1 Add Speech Proxy so Audrey can respond to hs.Speak
PR120 1.28.2 AudreyWavEx always trys to play file 0
PR121 1.29.3 Audrey not disabled after continuous no-response
PR122 1.30.0 Change from IE to INET for HTTP protocol
</pre>
</pre>
