MS_Client ERROR
    MS_Client ERROR
    Hello,
    Anybody know what could be causing this type of error
    "User name not found in the goups list"
    tb
      Thanks Christian ,
      It looks like there are no users to select from. It appears to be a blank pull down menu. I have tried adding users with no luck. I may try to download the latest HomeSeer app.
      Thanks again
                I tried your result and everything is working fine. See the screenshot:
                Could you show me what you get?
                Christian
                      Hi Christian there is a log.xml.bad and log file which are both "0" K in size , but no other securtity file
                      I restarted and no change
                      tb
                      thanks
                          Great Christian
                          I would like to try the BETA
                          I will give it a try
                          tb
                          Thanks for your great support
                              Hi Christian
                              I keep getting this error on the client
                              <B>8:56:10 AM - See the administrator of '190.160.1.100' server for authorization</B>
                              tb
