Integration with Touchpad
    Has anyone worked the message creation screen into the touchpad plug-in?
    I would like to have the ability to enter a message in touchpad to create announcements to the house.
    I can already do canned and web scraped annoycemnts through the events option. But I would like the ability to do Ad Hoc.
    If you can create an ASP for the messages, then Jeff can help you turn that into another menu option in TouchPad. He has done that for Weather already.
    Rick Tinker
    HomeSeer Technologies
    Rick Tinker (a.k.a. "Tink")
      Thanks I do use a modified version of Jeff's stuff.
      The problem is I can't figure out how to write an .asp for the message center.
      It appears to use pages built into the server or something. I can't find anything to modify or work from.
        Hanfseer,
        I have an asp page that allows you to select volume, voice and speed from dropdowns. Then a big text area to type what you want to have spoken.
        It would be pretty easy to modify the page to allow selecting between Speaking and Message Server. A dropdown could be added to select from the currently connected Message Server clients.
        If you are interested I can email you the speak page tonight to help you get started.
        Jeff Farmer
        HomeSeer user since March, 2000
        Wiring Wall
        HomeSeer
        Jeff Farmer
        HS 3, HSPhone
          Thanks!! That would be awesome!
          e-mail me at dhanford@hanfnetout.com
            Who needs to eat? I modified the speak page during my lunch break.
            Its attached here. If you want to use the Speak part, you will need to edit the dropdown with the voices.
            This has been tested with Message Server and ATT voices.
            I just got the NeoSpeech voices installed but have not had time to test this with them.
            I added this line
            strStyleMode = "touchpad"
            Leave it as is to use this with Touchpad. Change it to this:
            strStyleMode = ""
            to have the normal HomeSeer look.
            NOTE
            This requires the Include Scripts which are available via the updater.
            Jeff Farmer
            Wiring Wall
            HomeSeer
            Jeff Farmer
            HS 3, HSPhone
              Holy Crud man!
              Your the best!
              I am going to try this out right now.
              I have abuddy in Lawrence, Kansas... I'm going to have to make him take you to lunch.
                I am getting this error when I call the page in touchpad:
                Script error: Type mismatch: '[string: ""]'
                if Request.Form("sendMethod") = 0 Then Response.Send "checked"
                  Change it to:
                  <pre class="ip-ubbcode-code-pre">
                  if Request.Form("sendMethod") = "0"
                  </pre>
                  Also change the line:
                  if Request.Form("sendMethod") &lt;&gt; 0 Then
                  </pre>
                  to
                  if Request.Form("sendMethod") &lt;&gt; "0" Then
                  </pre>
                  Jeff Farmer
                  Wiring Wall
                  HomeSeer
                  Jeff Farmer
                  HS 3, HSPhone
                    If you want the All client to work you will need to change the line 31
                    <pre class="ip-ubbcode-code-pre">hs.plugin("message server").messagetoclient Request.Form("speakit"), "Message",Request.Form("msgType"),True,True,Request.Form("ms gSrvClient")</pre>
                    To:
                    <pre class="ip-ubbcode-code-pre">if Request.Form("msgSrvClient") = "All" then
                    Else
                    hs.plugin("message server").messagetoclient Request.Form("speakit"), "Message",Request.Form("msgType"),True,True,Trim(Request.For m("msgSrvClient"))
                    end if </pre>
                    Christian
                      OK...
                      Now the page will show up, but when I select Msg Server and hit speak it, I get this error:
                      Script error: Type mismatch: 'hs.SetVolume' hs.SetVolume intLoud,intLoud,intDev
                        Obviously this is pre-mature, but...
                        Is there a way to have it always default to the message server. In fact I don't even realy care to have the other option. I will always be sending it to my whole house audio system. I don't ever need to change the volume or voices.
                          I took a closer look and realized the speak section has several lines of code that are specific to my setup. I'll remove that and post it later tonight.
                          Jeff Farmer
                          Wiring Wall
                          HomeSeer
                          Jeff Farmer
                          HS 3, HSPhone
                            Thanks a million!
                            This is one of the last things I want to integrate... for now....
                              hehe, wait till you see how I'm using Message Server with the WebCam plugin.
                              Jeff Farmer
                              Wiring Wall
                              HomeSeer
                              Jeff Farmer
                              HS 3, HSPhone
