Is Any one seeing this : I have the client set to start up with windows 2000 works fine. But when with client running I shut down win2k System Hangs complaining about MS Client and sum error. (I will have to wright it down)In any case the computer wont shut down untill I tell it ok. Any body seen this? O the ver I have is : 2.3.155
MS_Client / Win2K Shutdown problem?
HS2 Environment
Zotac 1.83 GHz Quadcore
HomeSeer Way2Call
Netiom-Xap board
opnode 1-wire 1.2.7
Plug-In's
WeatherXML 1.0.0.32
Pwr Link USB 1.0.0.13
mcsTemp V6.2.0.14
mcsXap V3.0.0.0/3.0.0.20
IM Connector 4.87.2.5
Sip Connector 2.56.2.4
RFXCOM 15.0.0.22
Odroid X2
Asterisk 11.5.1
FreePBX 2.11.0.42
WebMin 1.720
Xap Switchboard by Mi4
There is no place Like 127.0.0.1Tags: None
cyvinec
I remember seeing something thing like that one or two times with WinXP but could not find anything and it’s not happening anymore.
Could you install the latest BETA from the HomeSeer Updater to see if you still got the error?
Christian
Christian I upgraded the message server and the clients and that took care of my problem!
Thanks !!HS2 Environment
HomeSeer Way2Call
Netiom-Xap board
opnode 1-wire 1.2.7
Plug-In's
WeatherXML 1.0.0.32
mcsTemp V6.2.0.14
RFXCOM 15.0.0.22
Odroid X2
Asterisk 11.5.1
FreePBX 2.11.0.42
WebMin 1.720
