Reconnect doesn't work?
    I may be doing something wrong. I have the reconnect time set to 30. If I restart the server, the client gets the big X saying it isn't connected. I was expecting that after the 30 seconds it would automatically reconnect. It doesn't unless I click on connect or reconnect. Is that a bug? I would hate to have to go to each client pc to reconnect after a reboot. Let me know what options I have. Thanks.
    James
    Running HS 3 on Win10 .
      No message!
      No. The client machine just shows an X on the icon in the system tray. I am using winXP on both client and server machines with homeseer 1.7.43.
      James
          I didn't explain correctly.
          All I do
          On the server. Click on "homeseer GUI" Message Server menu. Then click on the settings sub menu which opens a web browser based settings screen. I click on restart server button.
          At that point all the clients are permanently disconnected and never re-connect. The same thing happens if I reboot the server. The only way the clients re-connect is if I right click on the client tray icon and click on connect.
          The main reason this is important to me is because my server needs to be rebooted periodically and I don't want to have to go to each client to re-connect.
          I confirmed that my clients do not have zero on the reconnect field. I varied them from 35 to 65 seconds.
          James
            Originally posted by jasv
            All I do
              Agreed
              You are correct. That does work. Everything is ok now. Thanksl
              James
