can't locate MS_Client folder
    Hello,
    I have installed this on several clients in the past but I can not find the installed "MS_Client" folder. This usually located in the Program folder.
      No Luck
      Other than the zip file folder ther is a "MS_CLIENT.EXE-3B20D4FB.pf" a prefetch file..
        I never saw the prefetch file before you may need to reinstall the client.
          I tried to do that. This is on a fresh install of XP home. Is there a problem installing the client on the server?..
            No problem installing the client on the server.
            Dou you have the client installed in the "add remove program" in the control panel?
            You may want to try running the client from a folder without installing it. Look here form more info.
            Christian
              I'll give it a try
              Thanks for your help and a great program
                Install of client
                I had trouble installing the client version of 2.4. I had to install the 2.2.1 version from the website first and then do the automatic update. I spend a couple of hours trying to figure it out but my method worked so I moved on.
                Ditto on the great program. I love the ability to code the scripts using the custom editor and beinging able to run it without having to run a HS event. And it can be done from any computer with MS_Client installed.
                James
                Running HS 3 on Win10 .
