Need help with code to send image
cyvinec
Jim,
Here you go you will need to change the web server port and enter the client name if you want.
PHP Code:Sub Main()
dim LastImageName
dim serverport: serverport = 88
dim client: client = ""
LastImageName = hs.GetIniSetting("Thumbs", "LastImageName", "", "hspi_Hauppauge_Capture.ini")
'LastImageName = "c:\program files\homeseer\html\images\motionchart.gif"
LastImageName = Replace(LastImageName,"c:\program files\homeseer\html\","%HS_SERVER%:" & serverport & "\")
hs.Plugin("Message Server").MessageToClient "<img border='0' src='http://" & LastImageName & "'>",,0,1,0,client
End Sub
Christian
HTTP://c:\progran files\homeseer\html\capture\driveway\*.jpg". The replace function dose not seem to be doing anything. What am I doing wrong?
Jim
cyvinec
cyvinec
You can try this replace line I added all the optional parameter.
Code:LastImageName = Replace(LastImageName,"c:\program files\homeseer\html\","%HS_SERVER%:" & serverport & "\", 1, -1, vbTextCompare)
Code:dim strTemp: strTemp = "112233" strTemp = replace(strTemp,"1","33",1,-1,vbTextCompare) strTemp = replace(strTemp,"2","33",1,-1,vbTextCompare) hs.writelog "debug",strTemp
Christian
Thanks for putting up with my questions. The last line worked great. I do have one more question if it not to much trouble. If I wanted to give the message box a title that was a variable what would be the proper way?
Title=?
hs.Plugin("Message Server").MessageToClient "<img border='0' src='http://" & LastImageName & "'>","??????????",0,1,0,client
Jim
cyvinec
Jim,
What Windows version are you running? I knew I should not let optional variable empty but I wanted to keep it short. Too short I guess.
For the title on top of your script add.
PHP Code:dim Title
Title = "Your script title"
PHP Code:hs.Plugin("Message Server").MessageToClient "<img border='0' src='http://" & LastImageName & "'>",Title,0,1,0,client
Christian
