NeoSpeech voices Kate & Paul
    Can Message server client use Kate & Paul voices to speak?
    I installed them on the client computer and slected control panel/Speech Properties picked from voice slection dropdown NeoSpeech Paul 16K. I tested the preview Voice and Paul spoke but Message server client does not use it. I can get Merlin to speak but not SAPI.
    This is on a win2k box message server client 2.4.186 and SAPI Plugin checked. I also get this error in the message server. pop up also stop working when SAPI is checked
    8/13/2005 12:38:20 PM - Error 430 (Class does not support Automation or does not support expected interface) at line 340 in procedure AddMessageNow of Class Module clsAddData
    Any one have this working or is this beyond the programs capability?
    HS2 Environment
    Zotac 1.83 GHz Quadcore
    HomeSeer Way2Call
    Netiom-Xap board
    opnode 1-wire 1.2.7
    Plug-In's
    WeatherXML 1.0.0.32
    Pwr Link USB 1.0.0.13
    mcsTemp V6.2.0.14
    mcsXap V3.0.0.0/3.0.0.20
    IM Connector 4.87.2.5
    Sip Connector 2.56.2.4
    RFXCOM 15.0.0.22
    Odroid X2
    Asterisk 11.5.1
    FreePBX 2.11.0.42
    WebMin 1.720
    Xap Switchboard by Mi4
    There is no place Like 127.0.0.1
      Hi when I try this nothing happens no errors no sound.
      hs.Plugin("Message Server").SAPI_MessageToClient "This is a test"
      One thing I do notice is if SAPI plug-in is checked I do not recieve any popup messages and I also recive errors in the error log. If I uncheck SAPI popup messages work again and there are no errors in client log.
      8/13/2005 2:14:10 PM - Error 430 (Class does not support Automation or does not support expected interface) at line 340 in procedure AddMessageNow of Class Module clsAddData
      HS2 Environment
      HomeSeer Way2Call
      Netiom-Xap board
      opnode 1-wire 1.2.7
      Plug-In's
      WeatherXML 1.0.0.32
      mcsTemp V6.2.0.14
      RFXCOM 15.0.0.22
      Odroid X2
      Asterisk 11.5.1
      FreePBX 2.11.0.42
      WebMin 1.720
          Both buttons work with Kate 16K
          ~Bill
            MS_Client worked fine. Make sure they configure the SAPI plugin (message type) and it seems to use the Windows Default Voice.
            ~Bill
              Thanks Bill,
              Did you have the voice working with the client?
              Christian
                I beat you by 5 seconds...
                ~Bill
