Send a keystroke to network PC running Message_Client
    Hi Christian,
    I'd like to know how to send a keystroke to a client PC running Message_client? The goal is to kill a screensaver upon disarming the security system with the LCD panel in the hallway.
    Appreciate your response,
    Simon
    Simon,
    PHP Code:
    hs.Plugin("Message Server").keys "z"""true"client name"
      Working nicely, thank you very much Christian.
      Simon
        With a similar topic, is it possible to surpress the popup window but rather sending all information to baloon type message in the system tray? Upon receiving phone call, I will broadcast out caller information to all clients but for one, I use the MainLobby software and I'd like to surpress the popup but I still want Message_Client running so I can send a keystroke to disable the screensaver.
        Simon
          Simon,
          You will need to explain a little bite more how you send that message to your clients.
          I would not send the message to that client by script or set the time before closing the message box to 1 sec.
          Christian
            Hi Christian,
            I have an event set up in HS, triggered by on Caller ID available. Under Message Server tab, I have the following information:
            Client name, IP... -> blank
            Message Type: Info, Message Box ticked
            Title: Caller ID Info
            Message:
            Incoming call from:<br>
            <b>$CallerIDName.</b><br><br>
            Number: <b>$CallerIDNumber.</b><br><br>
            <a href="<A href="http://%HS_SERVER%:1500/phoneWeb?page=callerid">CallerID</a">http://%HS_SERVER%:1500/phoneWeb?page=callerid">CallerID</a>
            This way, all clients connected would get a message box. However, I'd like to somehow exclude one connected client.
            Simon
                Thanks Christian.
                Simon
