HS 2 HSP message to Message Server
    Need some help here. I havs HS2 with HSphone. I have an event set to trriger when a voice message is left. I have message server selected to send a message to all clients with the following info:
    A Message Has been Left in $MailboxName at $time, $date. The call is from $CallFrom, $CallNumber
    What I get at the client is: A Message Has been Left in $MailboxName at 10:00am, 02/24/06. The call is from $CallFrom, $CallNumber
    The mailbox that a message has been left does not seem to work also if I am remembering correctly neither does the callfrom & call number , I may be wrong about that but sure about the Mailbox name not working .
    I have include a screen shot of the settings. I may have something setup incorrectly. What are the two "Show boxes for???
    HS2 Environment
    Zotac 1.83 GHz Quadcore
    HomeSeer Way2Call
    Netiom-Xap board
    opnode 1-wire 1.2.7
    Plug-In's
    WeatherXML 1.0.0.32
    Pwr Link USB 1.0.0.13
    mcsTemp V6.2.0.14
    mcsXap V3.0.0.0/3.0.0.20
    IM Connector 4.87.2.5
    Sip Connector 2.56.2.4
    RFXCOM 15.0.0.22
    Odroid X2
    Asterisk 11.5.1
    FreePBX 2.11.0.42
    WebMin 1.720
    Xap Switchboard by Mi4
    There is no place Like 127.0.0.1
      Thanks , I gave it a try and saw that the Show boxes are gone but I still dont get the Mailbox name,CallFrom or CallNumber in the message to clients. All I get is the time and date info.
      I do notice that after the last debug about xml.... I see the info I want Mailbox name (Grey hawk) and call number ">361-xxx-xxxx</ p server Message to sent not its but Clients<> Here is the log debug:
      Debug~!~A Message Has been Left in $MailboxName at 12:16:01 PM, 3/4/2006. The call is from $CallFrom, $CallNumber
      HS2 Environment
      HomeSeer Way2Call
      Netiom-Xap board
      opnode 1-wire 1.2.7
      Plug-In's
      WeatherXML 1.0.0.32
      mcsTemp V6.2.0.14
      RFXCOM 15.0.0.22
      Odroid X2
      Asterisk 11.5.1
      FreePBX 2.11.0.42
      WebMin 1.720
        I did a test with the log.txt and all variable has been changed correctly using the event. Those debug line should not be there and the variable are not changed in the first debug line.
        Here what I get as test.
        A Message Has been Left in Grey Hawk at 2:53:48 PM, 3/4/2006. The call is from Frank Scott, 361-xxx-xxxx
        Christian
          Works Great, Had to reboot HS 2. All is well
          Thanks Christian
          HS2 Environment
          HomeSeer Way2Call
          Netiom-Xap board
          opnode 1-wire 1.2.7
          Plug-In's
          WeatherXML 1.0.0.32
          mcsTemp V6.2.0.14
          RFXCOM 15.0.0.22
          Odroid X2
          Asterisk 11.5.1
          FreePBX 2.11.0.42
          WebMin 1.720
            Great idea
            I have version 2 and I cant find anything in the events to do this. Any help for a newbee.
            Thank,
            Dan
            danielbo
              Broke after updating to HS 2.1.49
              This was working under 2041 but I updated to HS 2.1.49 look at the screen shot
              all the commands like $MailboxName & $callFrom are missing and there replaced with
              Invalid incoming data from the phoneWeb plug-in
              Please contact the plug-in developer.
              any ideas Christian
              HS2 Environment
              HomeSeer Way2Call
              Netiom-Xap board
              opnode 1-wire 1.2.7
              Plug-In's
              WeatherXML 1.0.0.32
              mcsTemp V6.2.0.14
              RFXCOM 15.0.0.22
              Odroid X2
              Asterisk 11.5.1
              FreePBX 2.11.0.42
              WebMin 1.720
                Something probably changed on HS Phone I will have to install that version to see what the problem is.
                Christian
                  Really Looks Interesting
                  This looks interesting, but I cant seem to find the plug in for it.
                  Could some give me some ideas on what I am looking for, Please.
                  danielbo
                  danielbo
                    danielbo,
                    If you are looking for the Message server plug-in, it is in the Updater. It is listed as "Message Server Plug-in BETA" and the current version is 1.4.0.274. I have been using it for a year or so and have had great luck with it.
                    Jeff
                      Upgraded to HS 2.1.66 to see if that would fix it. But no Joy.
                      Christian when do you think you will have a update to fix this?
                      HS2 Environment
                      HomeSeer Way2Call
                      Netiom-Xap board
                      opnode 1-wire 1.2.7
                      Plug-In's
                      WeatherXML 1.0.0.32
                      mcsTemp V6.2.0.14
                      RFXCOM 15.0.0.22
                      Odroid X2
                      Asterisk 11.5.1
                      FreePBX 2.11.0.42
                      WebMin 1.720
                          No problem I understand. with HS 2 in constant development and changes that change every time the wind blows its hard to keep up. At times I wish that I never left 1.7 but I did and now I must hope for the best. It has been getting better with each beta for the most part. I expect by the end of this year we will again have a stable platform to work from. The HS folks have been working hard to make it happen and some of the issues are from plugin builders building to one spec and then some change causes a problem. I thank you for all you hard work and trying to keep up with this.
                          just my 2 cents
                          Hang in there.
                          HS2 Environment
                          HomeSeer Way2Call
                          Netiom-Xap board
                          opnode 1-wire 1.2.7
                          Plug-In's
                          WeatherXML 1.0.0.32
                          mcsTemp V6.2.0.14
                          RFXCOM 15.0.0.22
                          Odroid X2
                          Asterisk 11.5.1
                          FreePBX 2.11.0.42
                          WebMin 1.720
                            I understand the frustration in trying to keep up with HS2 changes,
                            but does this mean that Message server will no longer be supported on HS2?
                            Should I remove message server from my list of plugins? If this last problem will not be fixed then any further changes in HS2 will just make message server further out of line and not supported. I don't want to really invest any effort in setting up many events and custom messages and find out a little later that the whole plugin is not being supported.
                            I believe that plug ins that are being sld through Homeseer should have a commitment to be supported , or at least have the project taken over by a third party.
                            jjsmd@yahoo.com
                              Guys,
                              Have you taken a look at Setup-->Phone-->Additional Phone Interface Options?
                              Here's what I have in the last caller message:
                              HTML Code:
                              Call from #CallerIDName# (#CallerIDNumber#) at #CallerIDTimeDate#. <br><br> <a href="http://%HS_SERVER%:5190/hspw?page=callerid">CallerID</a>
                              And, here's what I have in the last voice mail message:
                              HTML Code:
                              A voice mail message was left at #CallDateTime# by #CallFrom#.  The message length is #Length#.  The call came from #CallNumber#. <br><br> <a href="http://%HS_SERVER%:5190/hspw">Message</a>
                              Then, I have a couple simple events that are called to send the information to Message Server:
                                 sub message_server_display_cid()
                                 	hs.plugin("message server").messagetoclient hs.LastCallerInfo(1), "Incoming Call", 1,True,True
                                 end sub
                                 sub message_server_display_voicemail()
                                 	hs.plugin("message server").messagetoclient hs.LastVoicemailInfo, "Message Left", 2,True,True
                                 end sub
                              I think the replacement variables you folks are talking about (above) were created through collaboration between Christian and Jeff Farmer when he wrote phoneWeb. HS then bought phoneWeb from Jeff, and modified it. I don't believe they knew about the replacement variables, then, and that might be the disconnect. I've been using the methodology I've just related for some time with HS2, with no problem. The 2.1 beta seems to have trouble extracting info about the voicemail file, however, because I think it isn't getting closed. I've submitted a help desk ticket on the matter already.
                              Hope that helps someone.
                              --David
