HS 2 HSP message to Message Server
    #16
    David, quick question what ver of HS2 are you running.
    HS2 Environment
    Zotac 1.83 GHz Quadcore
    HomeSeer Way2Call
    Netiom-Xap board
    opnode 1-wire 1.2.7
    Plug-In's
    WeatherXML 1.0.0.32
    Pwr Link USB 1.0.0.13
    mcsTemp V6.2.0.14
    mcsXap V3.0.0.0/3.0.0.20
    IM Connector 4.87.2.5
    Sip Connector 2.56.2.4
    RFXCOM 15.0.0.22
    Odroid X2
    Asterisk 11.5.1
    FreePBX 2.11.0.42
    WebMin 1.720
    Xap Switchboard by Mi4
    There is no place Like 127.0.0.1
      #17
      HomeTech,
      I, too, am using 2.1.66, but I'm encountering a file release (my theory) issue in this version that is not enabling my voicemail code (above) to extract info from the file. It worked fine in 2.0.2041, however, so I think of this as a minor glitch to be resolved in the near future.
      --David
        #18
        Ok, well I did move up to HS 2.1.68 the other day and no change there. I just updated my signature to match. I will try the variables you have defined and see if that works. It looks like $ had changed to # for one thing. I will give it a try in the event set up and post back.
        HS2 Environment
        HomeSeer Way2Call
        Netiom-Xap board
        opnode 1-wire 1.2.7
        Plug-In's
        WeatherXML 1.0.0.32
        mcsTemp V6.2.0.14
        RFXCOM 15.0.0.22
        Odroid X2
        Asterisk 11.5.1
        FreePBX 2.11.0.42
        WebMin 1.720
          #19
          Ok the last caller in the phone settings still works fine as well as last message left.
          But when I setup a event triggered by message left and try to use message server to send to clients $MailboxName & $callFrom and so on it does not populate the info in a message. Was'nt sure if we were talking about the same thing.
          HS2 Environment
          HomeSeer Way2Call
          Netiom-Xap board
          opnode 1-wire 1.2.7
          Plug-In's
          WeatherXML 1.0.0.32
          mcsTemp V6.2.0.14
          RFXCOM 15.0.0.22
          Odroid X2
          Asterisk 11.5.1
          FreePBX 2.11.0.42
          WebMin 1.720
            #20
            This is what i am tring to get working from the action tab of an event.
            HS2 Environment
            HomeSeer Way2Call
            Netiom-Xap board
            opnode 1-wire 1.2.7
            Plug-In's
            WeatherXML 1.0.0.32
            mcsTemp V6.2.0.14
            RFXCOM 15.0.0.22
            Odroid X2
            Asterisk 11.5.1
            FreePBX 2.11.0.42
            WebMin 1.720
              #21
              here is the rest of the shot.
              HS2 Environment
              HomeSeer Way2Call
              Netiom-Xap board
              opnode 1-wire 1.2.7
              Plug-In's
              WeatherXML 1.0.0.32
              mcsTemp V6.2.0.14
              RFXCOM 15.0.0.22
              Odroid X2
              Asterisk 11.5.1
              FreePBX 2.11.0.42
              WebMin 1.720
                #22
                David:
                I am not sure I get what you are saying ,
                in phone setup advanced phone settings I have the following:
                You have a call from #CallerIDName# from #CallerIDNumber#
                but when I try to setup an event that has as an action the message server, and in the message I put #CallerIDName#, I get the message sent with
                #CallerIDName# showing in the message , not the actual name.
                Joe
                jjsmd@yahoo.com
                  #23
                  Hi, guys, I'm not sure if I'm going to answer this the correct way, but I here goes. I did not have any success getting Message Server to recognize the parameters directly in and of itself, so what I did was create the functions I shared above which are executed by HS events. Thus, one event has a trigger of "on caller ID available" and the other has a trigger of "on message left". In both cases, I run the script in a manner such as this: page_cell_phone.txt("message_server_display_voicemail","")
                  --David
                    #24
                    Its Working now!
                    Updated HS2 to 2.1.75 and all is working again with Homeseer phon and Message Server events!
                    HS2 Environment
                    HomeSeer Way2Call
                    Netiom-Xap board
                    opnode 1-wire 1.2.7
                    Plug-In's
                    WeatherXML 1.0.0.32
                    mcsTemp V6.2.0.14
                    RFXCOM 15.0.0.22
                    Odroid X2
                    Asterisk 11.5.1
                    FreePBX 2.11.0.42
                    WebMin 1.720
