I have an event whereby when there is no motion in a particular area I have a touchscreen shut off. I do this via:
&hs.Plugin("Message Server").ClientMonitorOff (Basement)
I just installed the client on a second PC. When message server shuts the monitor for "Basement" off it is also shutting off the monitor for the other PC. Do I have some incorrect syntax? Using HS 2.0.2041 and the MS beta from the updater. Clients are (I think) 2.4.x
