message to one client only?
    I have been using this excellent plugin for a long time. It is an excellentaddition to Homeseer.
    My problem now is that I have usually sent messages to all of my clients at the same time.That works flawlessly. But I now have tried to send individual mesages to individual clients and that doesn't seem to work. I either have to have the messagepopup on all clients, or if I try to send to one client in particular no message gets sent.( i tried by name or by ip withno diff) The client shows up on my client list,but I can't get a message to it.
    jjsmd@yahoo.com
    Just to elaborate:
    If I send a message to all clients (by leaving the space blank) thenall theclients getthemessages, but when I try to send amessage to one client only Idont get the message acccross?
    Any suggestions?
    jjsmd@yahoo.com
      Just so you won't think it's something you are doing wrong.
      I am seeing the exact same thing.
      Jeff Farmer
      HS 3, HSPhone
        I am not seeing this using the script function what are you using to send the message?
        Christian
          I'm using the add event and then fill in the blanks for message server
          jjsmd@yahoo.com
            With HS1 or HS2?
              Me too, HS2
              Don
                I'm using HS2.
                I just verified what you said, the script function does send out messages to individual clients. But if you create an event using the event boxes it doesn't seem to work unless you send out a universal message to all clients
                jjsmd@yahoo.com
                  No I'm still running HS1. I don't know for HS2.
                  No problem HS1
                  Christian
                    jjsmd,
                    Can you paste an example that you are using in a script.
                    I have several scripts using similiar to this:
                    PHP Code:
                    s=hs.Plugin("Message Server").messagetoclient "Test","Caller-ID",1,1,0,"HomeNGo"
                    It doesn't work. If I leave off the "HomeNGo" it does send the message but to every client.
                    Jeff Farmer
                    HS 3, HSPhone
                      Forgot to post that I am using HS 2 as well.
                      Christian,
                      Come on up to version 2. I finally upgraded a few weeks ago and it went really well. No complaints.
                      Jeff Farmer
                      HS 3, HSPhone
                        If I remember correctly, the last change I did was about something like that after a Windows updates.
                        My server is old (PII) running Win98 and HS1.
                        I will be on vacation next week so I will try to fix that or I am very close to have the .net beta version available to. I will go with the fastest.
                        Christian
                          I just put this in a 1 line script
                          &hs.plugin("message server").messagetoclient "this is a test","title", , , 1,IBM_LENOVO
                          and it did work as a script. but the events still don't work
                          jjsmd@yahoo.com
                            Christian,
                            I am willing to wait for the .net version.
                            Keep me in mind for testing your new version. I use the Message Server plugin for a lot of things. E-Mail Reminders, HSTV Reminders, Caller-ID and Voice Mail Notification. I'd say Message Server is by far my most used plugin.
                            Jeff Farmer
                            HS 3, HSPhone
                              Any further news on this problem?
                              jjsmd@yahoo.com
