If you are a Message Server user having one hour or so this weekend and are interested to test Message Server .NET.
My goal is to have a version comparable with what you are running (some exception that did not make it to .NET). I will be available for quick fix (if I can) via email and msn chat from Friday 7:00 PM to Sunday 1:00PM with some little naps interruption for still being able to think. Once you are running the .NET version I made a script to get the beta update easily. Running a script from an event and restart HomeSeer could not make it easier. The scripts editor is not finished just the minimum to edit a script it’s like another program that I have to write I will do this right after everything run smoothly.
I first said one hour but it could be less if you are only using couple of events to send message and control the device from a client.
After if you decide to keep running the .NET version you will have a 2 to 3 weeks advance before it get to the updater again.
<hr>
Send me an email or private message.
Your Message Server usage:
When you are available to test:
The number of client you are normally running:
The Version of HomeSeer you are running:
Do you use the Agent on the client:
Best regards,
Christian
<hr>
Best regards,
Christian
