Message Server BETA 3.0.1.20 is available in the HS updater
This topic is closed.
    Hi,
    This version will remove security and log file of the vb6 version so always good to make a backup before any changes!
    Post here any issues, request or things that I could have miss while rebuilding the applications
    Christian
    More info can be found on the web site http://www.cyvinec.com/message_server
    Problem
    Hi Christian:
    I'm running the new beta and having the following problem when sending a command. I don't know if the syntax has changed or not butn this is what I am seeing when sending a command:
    hs.Plugin("Message Server").MessageExeLink "c:\MonitorControl.exe", "//mOff","","touchtwo"
    Error
    Public member 'Plugin("Message Server"' on type 'hsapplication' not found.
    Args: 4
    Args:0 Message Server"(.MessageExeLink "c:\MonitorControl.exe
    Args:1 //mOff
    Args:2
    Args:3 touchtwo
    -Rob
        Thanks Christian.
        I was unaware of the monitor client functions. Worked like a champ!
        -Rob
          I'm having a problem because the client is looking for a directory "c:\windows\media" which I don't have since I am running Windows 2000 Pro which has a "c:\winnt\media" directory.
          Dick
          HS PRO 2.5.0.81, WinXP, IE8, Shuttle XS35V3, 2.13GHz, 4GB, 40GB SSD drive, AC-RF2, ADIOcelot, Message Server, TI103, SNEVL CID, pjcOutlook, MCSTemperature, Powertrigger, BLBackup, BLFloorplan, BLIcon, BLOccupied, BLRadar, BLRfid, BLLogMonitor, ACPUPSD, UltraECM, WeatherXML & Stipus' script connector. 500+ devices, 260+ events, 1-wire weather station + temp/humidity sensors & Oregon Scientific temp & humidity sensors & 2 Brultech ECM-1240s
            Slight spelling error
            During my problems with the client, I noticed that the error message displayed in the homeseeer log file has a spelling error:
            3/4/2008 9:35:44 PM ~!~Message Server ~!~Client Diconnected : on computer:
            "Diconnected" should have an "s" in it - "Disconnected"
            Dick
