I wonder if?
    I wonder if?
    Hi Christian,
    I have been experimenting with Lantronix Xports for some time. I built a sudo TCPIP stack for homeseer, with limited success. I was ready to go back to USB to Serial if I had to. Then I saw your Message Server.
    Can I send a tcp message to a single ip. IE 192.168.2.250 "A04on" then disconnect. I use VB6, Homeseer 2, and my addon uses the HomeSeer1 interface.
    I can't use a client do to the restrictions on the Xport.
    If your code can do this, I would very much like to buy your addon.
    Thanks for your time
    Brad
    bsnedek@gmail.com
      Hi,
      This should help you have something working in .NET
      http://board.homeseer.com/showpost.p...34&postcount=6
      Christian
