Hi Christian,
I have been experimenting with Lantronix Xports for some time. I built a sudo TCPIP stack for homeseer, with limited success. I was ready to go back to USB to Serial if I had to. Then I saw your Message Server.
Can I send a tcp message to a single ip. IE 192.168.2.250 "A04on" then disconnect. I use VB6, Homeseer 2, and my addon uses the HomeSeer1 interface.
I can't use a client do to the restrictions on the Xport.
If your code can do this, I would very much like to buy your addon.
Thanks for your time
Brad
bsnedek@gmail.com
Brad
bsnedek@gmail.com
