In recent days the temp outside where I have an MD3020E sensor giving me trouble is swinging slightly above to slightly below freezing, with humidity levels generally above 85%.
I noticed my outdoor humidity sensor has had readings of between 33 and 40 over the past few days when the humidity was much closer to 90% - 100% outside.
Each "valid" (but not inacurate) reading was followed by hours of "???" readings, meaning my HA has been acting on bad advice. Right now the reading is 95, which is more accurate. Temp outside is slightly below freezing.
Ignoring bus reliability issues for the moment, do these sensors cease to work at certain temperatures or humidity levels?
On a potentially related matter, what's the issue with "35" being a bad reading according to posts (and features) in mcsTemperature?
