I have a TEMP08. I only had a DS18S20 temperature sensor connected but then replaced that with a MD3020E containing a DS18S20 temperature and a DS2438 humidity sensor. I am now getting ??? readings for the humidity sensor only and understand I need a 100K Ohm resistor. Since this is the first extraneous sensor connected to the TEMP08 is there alternative wiring to avoid the one wire reflections?
Alternative to 100 Ohm Resistors to Avoid ???
This topic is closed.
Hi Jim,
The 100 ohm (not 100K ohm) resistors are normally only needed if wiring the 1-Wire bus in a star configuration. Adding just the MD3020E to a TEMP08 should not require the resistor.
Having said that, the ??? readings are a good indicator that you are probably running in parasitic powering mode for the humidity sensor. Make sure you are locally powering the sensor and that the P/L jumper is in L mode.
Mitch
When to use or not use parasitic power
Mitch,
Do you have a rule of thumb regarding the use of parasitic power in a star configuration with various flavors of devices? I currently am using a Temp08 and a Temp05 with most current firmware (software). I get "???"'s and the inability to see devices on the on board temperature sensors on both of these. I also get occasional "???"'s and on the weather station and combo humidity / temperature sensors. I have installed 100 ohm resistors on the most problematic devices and I still see occasional errors.
IE: (haven't restarted HS in a couple of weeks but here is the error count on the humidity sensor which one of many of my sensors). This sensor is connected via category 5 with only the sensor on that run of about 40 feet or so and I am using a resistor for this run.
<TABLE cellSpacing=1 cellPadding=0 width="100%" border=0><TBODY><TR><TD class=tablecellcustom>Total Temp05 Errors=2878 : Last Error with device T42</TD><TD class=tableroweven>Temperature-MCS-T8</TD><TD class=tableroweven>TEMP05 Error Count</TD><TD class=tableroweven>t62</TD><TD class=tableroweven noWrap>Monitor</TD><TD class=tableroweven noWrap>Today at 2:18:40 PM</TD></TR></TBODY></TABLE>
<TABLE cellSpacing=1 cellPadding=0 width="100%" border=0><TBODY><TR><TD class=tablecellcustom><TABLE><TBODY><TR><TD vAlign=center align=left>39%</TD></TR></TBODY></TABLE></TD><TD class=tableroweven>Temperature-MCS-T8</TD><TD class=tableroweven>Humidity - B326H - Kitchen</TD><TD class=tableroweven>t42</TD><TD class=tableroweven noWrap>Humidity</TD><TD class=tableroweven noWrap>Today at 2:20:40 PM</TD></TR></TBODY></TABLE>
I noticed on your WEB site you mention parasitic power for the AAG weather station. As all of my runs are separate CAT5 connections should I consider parasitic power on the combo Humidity/Temperature sensors as well?Last edited by Pete; February 27, 2006, 03:39 PM.- Pete
Auto matorHomeseer 3 Pro - 3.0.0.548 (Linux) - Ubuntu 18.04/W7e 64 bit Intel Haswell CPU 16Gb
HS4 Pro - Ubuntu 22.04 / Lenova Tiny M900 / 32Gb Ram
HSTouch on Intel tabletop tablets (Jogglers) - Asus AIO - Windows 11X10, UPB, Zigbee, ZWave and Wifi MQTT automation-Tasmota-Espurna. OmniPro 2, Russound zoned audio, Alexa, Cheaper RFID, W800 and Home Assistant
Originally posted by PeteI currently am using a Temp08 and a Temp05 with most current firmware (software). I get "???"'s and the inability to see devices on the on board temperature sensors on both of these. I also get occasional "???"'s and on the weather station and combo humidity / temperature sensors. I have installed 100 ohm resistors on the most problematic devices and I still see occasional errors.
With regard to
Originally posted by PeteAs all of my runs are separate CAT5 connections should I consider parasitic power on the combo Humidity/Temperature sensors as well?
Mitch
Thanks Mitch. Yes currently my AAG weather station / rain guage just connect to CAT5 and directly into TEMP08 (with a 100 ohm resistor on the TEMP08 side). Just two wires. By parasitic power u mean an additional two wires of 5V eh? I currently do not have local power for my "first gen" combo temperature / humidity sensors. Thanks for your suggestions.- Pete
