I have a Temp08 that I've been using with McTemperature plugin. Up until recently I only had one sensor attached to it (the board on the sensor is stamped with MD3020a). I just purchased a temp/humidity sensor board from hobby boards. Here's a link to it.
So I see two new sensors displaying in HS, but they both display as temperatures. Michael told me I need to config the sensors and/or the temp08, using hyperterm or his plugin or something. He mentioned something about using the TYP command. I don't know what or how to do, exactly. any help for a newbie?
Here's a copy of what I get when I do the ini command:
17:28:48 | [Sent to Temp05: INI ]
Reading Sensors...
01 6800000075129226 DS2438 OK P V
17:28:49 | 02 1D000800E95C3E10 DS1820 OK P
17:28:50 | 03 0B000801392DCC10 DS1820 OK P
17:28:50 | 04 7E000000A8D51C26 DS2438 OK P ?
17:28:50 |
Update interval = 01 minutes
17:28:51 | Temp display = F
17:28:51 | Serial # display = On
17:28:51 | Wind dirn reverse = Off
17:28:51 | Debug = Off
17:28:51 | Some temp sensors Parasitic powered
Qty of DS1820=02
Qty of DS1822=00
Qty of DS18B2=00
Qty of DS2438=02
17:28:53 | FRI 00:31:37
04[7E000000A8D51C26]=?
17:28:54 | Ent
17:28:54 | Temp05 Error= ??? Responseer type:
17:29:23 | [Sent to Temp05: DIS ]
17:29:23 | ? Entry error
17:29:23 |
17:29:23 | >
17:29:32 | [Sent to Temp05: DIS ]
17:29:32 | 01 6800000075129226 DS2438 OK P V
17:29:32 | 02 1D000800E95C3E10 DS1820 OK P
17:29:32 | 03 0B000801392DCC10 DS1820 OK P
17:29:32 | 04 7E000000A8D51C26 DS2438 OK P ?
17:29:32 |
17:29:33 | Temp display = F
17:29:33 | Serial # display = On
17:29:33 | Wind dirn reverse = Off
17:29:33 | Debug = Off
17:29:33 | Some temp sensors Parasitic powered
Qty of DS1820=02
Qty of DS1822=00
Qty of DS18B2=00
17:29:35 | Qty of DS2438=02
17:29:35 | FRI 00:32:20
17:29:35 | >
17:29:35 | Reading Sensors...
Voltage #01[6800000075129226]=00.05V 05.00V
Temp #01[6800000075129226]=45.90F
Temp #02[1D000800E95C3E10]=67.90F
Temp #03[0B000801392DCC10]=65.77F
Temp #04[7E000000A8D51C26]=65.21F
FRI 00:33:19
17:30:34 | Reading Sensors...
Voltage #01[6800000075129226]=00.12V 05.00V
Temp #01[6800000075129226]=45.66F
Temp #02[1D000800E95C3E10]=67.77F
17:30:38 | Temp #03[0B000801392DCC10]=65.66F
Temp #04[7E000000A8D51C26]=65.00F
17:30:40 | ><!-- / message -->
Reading Sensors...
17:28:50 |
Qty of DS1820=02
Qty of DS1822=00
Qty of DS18B2=00
Qty of DS2438=02
17:28:54 | Ent
17:29:23 |
17:29:23 | >
17:29:32 |
Qty of DS1820=02
Qty of DS1822=00
Qty of DS18B2=00
17:29:35 | >
FRI 00:33:19
