Hello,
I am thinking to use a hobby-boards counter sensor to measure my AC unit fan speed. The counter seems to be the easiest solution since I already have the TEMP08 that supports it.
I can design and install a tiny reed switch and attach it to the AC housing so it will be opening (or closing) once on every rotation of the fan axle. The fan is variable and its speed might be from 30 to 1500 rpm (I am guessing the range) but I am not sure if the counter throughput would be enough to handle that significant amount of data. Will it?
Is there a script that would be able to convert
