Aside from rxd, txd and gnd does the temp08 need rts/cts (or any other pins) to operate. I am using just tx, rx and gnd (pins 2,3,5) as well as the db9 shell ground. The two ends of the serial cable go to open house enclosure / punchdown and on ocassion I will get junk displaying in Hyperterm. Hyperterm is configured at 9600 8n1.
serial pins needed
This topic is closed.
Originally posted by rmorton27 View PostAside from rxd, txd and gnd does the temp08 need rts/cts (or any other pins) to operate. I am using just tx, rx and gnd (pins 2,3,5) as well as the db9 shell ground. The two ends of the serial cable go to open house enclosure / punchdown and on ocassion I will get junk displaying in Hyperterm. Hyperterm is configured at 9600 8n1.
Make sure Hyperterm is configured for no hand-shaking (Flow Control=None) so that it ignores any other connections on the DB-9.
Mitch
Thanks for confirmation; those were/are my settings. Anyway I found I had an old Ethernet/serial gizmo in my old junk box which actually works out better for the location and my use so all is well whatever the real issues is/was with my cabling/setup.
No need to answer but out of curiosity can a ground loop like the type that induces hum in audio equipment contributes to the junk data (they were all the same funny characters) that I would see from time-to-time when I was running on the serial cable? They would always follow the valid data streaming from the temp08 and would start and stop as if by magic.
-rick-Rick
-rick
