plugin causing issues with events firing.
This topic is closed.
    When I have this plugin enabled, my events (recurring or triggered) are delayed by various times. So if I have an event that is triggered by a received x10, I can see the x10 received but the event is delayed in running anywhere from 5 seconds to almost a minute. If I disable this plugin, everything returns to normal and works fine.
    With this plugin, I run an event every 2 minutes that records the temps of 8 different areas. Then every 5 minutes I run another event that records the high and low of each zone.
    Is anyone else seeing anything like this?
    If the high and low are via the min() and max(), your problem may be that you are growing the CSV file immensely quickly. It can take a very long time to load and parse a large CSV file. Ideally you would calculate the values on a daily or so basis and then auto-truncate the file. (which right now I don't think I've provided for.)
    Try truncating the CSV file and see if your event times return to normal.
