I've been scarce for a while. Hope I didn't miss too much. But for some of you it will be worth the wait!
PowerTrigger has been significantly enhanced, but is still in need of testing. It's free; I still don't envision that changing. Pushing it to the finish line is just becoming a chore.
So here's what's new.
I wrote the camera extension because I have several such cameras and was using PySoft's ActiveWeb Cam. It's a processor and bandwidth hog, always grabbing images even when nobody is watching, and recompressing every image all the time. It also doesn't play super-well with HomeSeer. It has one advantage - full-motion video. But I found I seldom can use that, for bandwidth reasons, when not home anyhow. Certainly not from my cellphone. So I wrote a replacement.
If you are a skilled power-user of HomeSeer who wants to play with this new version of PowerTrigger before it's fully baked, please send me a PM. The camera features currently require editing an ini file by hand, so it's not yet for novices.
Thanks!
- Internet Camera support
- Up to 9 cameras supported
- Interfaces via HomeSeer Actions, so Jon00 interfaces work with it; see attached image. Yes, those direction and refresh buttons work.
- Can retrieve images and put them into a HomeSeer accessible location, so you don't need to open more ports to the outside world
- Supports Up/Down/Left/Right on Toshiba and Panasonic cams (others may come)
- Configurable security levels, so you can force all to go offline or just "inside" ones for privacy.
- Archiving functions to make creating lists of images easier.
- File Operations
- Deletes by file pattern or mask
- Can limit it by age - Only delete files more than X hours or days
- Can limit by count - Keep the X newest matching files, delete the older ones.
- Can limit by size - Keep the newest X MB of files matching this pattern, delete the rest.
- Has a "log only" feature so you can test it thoroughly before risking data.
- Complex File Logging
- Insert the string into a file, newest at the top of the "log" section
- Allows the log to be, for example, in a table in the middle of a file
- Multiple strings can be concatenated, including HTML delimiting tags
- Device Value, String and Last Changed
- All from drop-down menues
- To any file.
- Prevents duplicates automatically (due to HSM100 multiple-fires)
- And it can automatically limit the number of entries, aging off old ones.
- And a few fixes/tweaks, such as the Average function and adding /100 to the CSV device logging.
Thanks!
