A couple of questions.
First, I was unsuccessful in getting an event to run from a sequence.
1) From the powertrigger screen, I built a trigger called Power Test 01 with A1 On and A2 Off within 3 seconds.
2) I built an event to trigger from Power Test 01 to speak a few words.
3) From within homeseer, I moded A1 On and A2 Off within three seconds.
4) The event didn't run.
The event did run manually.
Second, does power trigger only handle two sequences? I assume the way to increase this is to create a virtual switch that is turned on with the first sequence and then that switch is used as a condition in the event for the second sequence.
Thanks, as always, for any help in either matter.
Seth
Seth
