TechnoCat:
I know you've moved on from this plug-in (and evidently Homeseer in general) but I have a need if you still have interest.
As many of the values of my devices are stored as integers, getting them back to their real, floating point state requires dividing by 10, 100, or 1000, depending on the resolution of the data.
For example, my CurrentCost power monitor's watt variable stores the actual watts as an integer (56160), and the real value is of course 561.6 . I'd like to store these data in a CSV logged with PowerTrigger, but the only options are to convert between C and F, divide by 10, or set to 1 or 0.
It would be great if you could add "divide by 100" and "divide by 1000" to the list of options available. That way we would be able to store the data as it is.
Thanks for the consideration!
Gayle Snedecor
Gayle Snedecor
