DATA\DooStat. Log name is debug.log.
TXB-16 Problem...Jim?
This topic is closed.
termite
Jim, The log shows three attempts to retrieve each status from the stat, then states "Unable to recieve status from the thermostat".
I plugged the TW523 directly into the Powerlinc / Testerlinc line monitor and it showed all three of the staus requests, each followed by the proper status.
So, the stat appears to be performing properly, but the plugin is not recieving the predim command. Is there any way to see if Homeseer is recieving the predim command? The log does not display predims. Thanks
termite
Yes, I tried a couple different house codes. The thermostat is recieving and sending the proper house code. I was wondering if my Ocelot may have something to do with this, as the Ocelot is handling the X-10.
termite
Jim, I found the problem last night. I could send, but not recieve Preset dim commands through my Ocelot. It turns out that when I moved my system, I had to download and reinstall the executive program from the Ocelot website. As it turns out, I installed an old version (ver. 1.7) of the executive program I had in an old email and off she went! Thanks so much for your help.
