I am trying to use the temperature range for a condition. I want an event to proceed if the temperature on my RCS T15B thermostat is within a certain range. Do I need to have a script capturing the current temperature from the thermostat? It is polling every 30 minutes, so I thought the HomeSeer program would know the temperature, but the event does not get triggered. Thanks.
Using temperature range condition for event
This topic is closed.
I'm not familiar with this plugin, but if you can't get this working, take a look at the my.Trigger plugin (link in sig), which supports triggering events based on range using data stored in a device string.HSPRO 2.4 (ESXi 4.1) | my.Alert NEW | my.Trigger | HSTouch | ACRF2 | UltraM1G | BLWeather | BLLan | Rover
(aka xplosiv)
Do You Cocoon? Home Automation News, Tutorials, Reviews, Forums & Chat
This is easy to do in a simple event if the plugin provides the temp date in a numeric format. Most plugins store the data in device values multipled by 10. So the first thing to do is find out if you have the temps in deviceValues by doing something like this using the control button , Immediate Script Command box. &hs.writelog "data", hs.deviceValue("a1") where a1 is the device holding the temp value. Then the range is entered in the event as 7200 ... 8500 where 7200 is 72 and 8500 is 85
