RCS X10 Plug-in sending wrong commands
  • RCS X10 Plug-in sending wrong commands
    I am having a great deal of trouble getting my two TX15B thermostats to work with my new HomeSeer device. As an aside, because of this, I thought I would install DooStat, which I found does not recognize that I have a higher version of HS Pro than 2.1 (I have 2.5). In any case while troubleshooting, I discovered that when I change the properties of my thermostats, for example, setting autosend to ON (unit 4, preset dim 27), the plug-in sends safemode OFF (unit 4, preset dim 26). Does anyone know where the plug-in gets the command table, so I can look at it and possibly modify? Thanks and Happy Holidays to all! Elliott
    PROBLEM SOLVED: As per documentation for this plug-in:
    "Notes:
    - References to "Preset Level" are equivalent to X10 preset dim + 1 to be consistent
    with RCS documentation that refers to Preset Levels 1 to 32"
    Last edited by Richel; December 26th, 2010, 08:32 AM. Reason: I figured out the issue.
