Contacting HomeSeer This Week
See more
See less
Polling from a script?
  • Polling from a script?
    One of my Stats is a TX10B which is functionally similar to the TX15B, but no autosend. As a result, I have had the plugin set to Poll every so often. I want to change that and poll in an event based on measuring when the furnace comes on or goes off.
    I have the hardware and 2 events that do that part, they operate a duct booster. I want to manually poll the stat when those events execute. Polling is not one of Event Actions provided by RCS10 plugin. I checked the docs I could find but didn't see this.
    Does any one have the method name or know a script command to poll stats using RCS X10? Is there a generic poll function for the HS Thermostat device type?
    Any help appreciated.
    Thanks, Paul
    Paul
    Try hs.PollDevice( "A1" ) change the house and unit code to your device.
    -Rupp
      Rupp, The docs say that the TX1xB units use an entire house code. I've observed the plugin talking to my status using 6 (status) and 15 (Settings). These aren't the usual response codes used for standard 2 way x10 modules.
      That leads to an idea. I can send those X10 unit code 6 messages that the plugin uses to the poll stat that I can see in the log. I can add those to the event and assume the the plugin takes what it gets (as opposed to sending commands and waiting.) I can get the x10 commands and presets out of the log.
      I'll give that a try, but also take additional ideas as well
      Thanks.
      Paul
        DooStat has a polling Event Action as well as one for polling Temperatures only. This helps with RCS TX10B. I'm might be the only person in the world that cares at this point , but for the sake of documenting here it is.
        I can also confirm that Doostat is .NET and should survive the entire trip to HS3 unlike the current RCS Plugins (VB6 COM)
        Paul
