Originally posted by Blade
Router Traffic Monitor Plugin for Homeseer 2.0
This topic is closed.
Jeff Farmer
HS 3, HSPhone
Pretty sure, it's a version 1. I have had it for many years.--
Jeff Farmer
HS 3, HSPhone
Originally posted by BladeSteve,
Please forward the router logs to your HS computer and then run the VB.net standalone program that I attached near to top of the thread (it is called Router Logger) and capture the information it sends to you and then send me the output from the program. I think you will need to use port 162, but it could be 514.
When you have the logs from my stand-alone program, attach them here.
TIAAttached Files
Just an FYI...
I am testing the plugin now with Jeff (CFGuy) and he said it is running ok.
I am now adding some new features to it such as web interface pages, ability to choose Access or SQL server as the database, a router activity page where you will be able to customize the router logs displayed, and more.
Jeff has a Linksys BEFSR41 V1. I have added the parser for the BEFSR41 V3 and the BEFSR81 V3, but have not tested those ones yet.
Hopefully I can have a plugin in the updater for trial next week sometime (I hope).
I will keep you informed.
Cheers,
Steve
Will your plugin be able to tell when a person access's a site or page on the HS server. Lets say I would browse to a page on my website for weather, my script or event then checks the contents of the weather device and plays a clap of thunder if it were raining. If so, man think of the possibilities, turn on a light when you browse to the page that shows your webcam of a certain area.
Im reeling here. Tell me more.
Later, Terry
Originally posted by tman1Will your plugin be able to tell when a person access's a site or page on the HS server. Lets say I would browse to a page on my website for weather, my script or event then checks the contents of the weather device and plays a clap of thunder if it were raining. If so, man think of the possibilities, turn on a light when you browse to the page that shows your webcam of a certain area.
Later, Terry
At first thought, I dont see any reason why this would not work with the plugin. I will test it here.
I am going to create a new thread for Router Traffic Monitor feature requests and please have everyone post them there even if they have been mentioned here already.
Later, Terry
All of this can be done without a plugin. When you browse to a page that has your web camera on it simply add a hs.execX10 "A1","On",0,0 to the page and this will turn the light on. The same for the weather. Simply add a couple of lines of code that if raining then play thunder wav.
Actually, it depends on how your router handles internal traffic. Mine does not log internal so the Monitor plugin would never know that you were hitting a particular page. External traffic would be easy to track with this.--
Jeff Farmer
HS 3, HSPhone
tman,
I tried testing that and my router did not log it. I suspect it's because the actual page is not routed thru no-ip.com. I'm not a network expert. I only know enough to be dangerous with my home network, but the way I understand it, is that no-ip.com just provides the dns redirect to your computer. So the initial request would go out to no-ip.com, be told to go to your server, and then all the traffic just goes straight between your server and your computer. I'm sure we have several guys here that can correct me so maybe someone will post a better explanation.--
Jeff Farmer
HS 3, HSPhone
Blade, great job on this plugin. Now I just have to install HS2 (maybe in 2 weeks whenthe wife goes out of town and I can burn the nidnight oil guilt-free).John
Hardware: i5-6400T w/16GB RAM & SSD w/HS3Pro, Z-Net, Harmony Hub x2, Echo Dot x2, Ocelot
Plugins: Z-wave, HSTouch, BLBackup, Harmony, GTS CPUXA, UltraMon3, Nest
HSTouch: Multiple Android Devices; 5 x ToteVision MD-1001 10.1" Win 7 Tablets
Devices: Cooper RF9501 x4, RF9517 x6, RF9534 x1, RF9540-N x7, RF9542 x1, RF9542-Z x2, RFHDSCG x1, RFWC5 x5; Intermatic HA02 x6; FortrezZ MIMOLite x3; Leviton VRPD3-1LW x4, VRR15-1LZ x6; Nest Tstat & 9x Protects; Dragon PD-100 x3, PA-100 x3
