Welcome
This topic is closed.
This is a sticky topic.
    Welcome
    <b>Overview</b>
    The Router Traffic Monitor Plug-in for Homeseer allows the user to monitor the incoming and outgoing traffic on their router. It will also allow event triggers to be added to act on the router logging. This plug-in is written in VB .Net and requires Homeseer Version 2.0.1945 or later.
    You will be able to view various reports on the router log activity in your router that will help you determine the volume your router is actually processing.
    In order to use this plug-in, your router must be able to enable logging and redirect the logging to a specific computer on your network. Some routers do not come with this functionality loaded in their current firmware and it may be necessary to use a 3rd party firmware such as Sveasoft or HyperWrt.
    It is important to note that if your router can log to a specific computer on your network and your router is not in the list of routers in the plugin, you will need to reference the support forum above and look for the Router Logger stand-alone VB.Net application and run it to gather the logs from your router so that I can create a parser for your router and add it to the plugin.
    Feature Requests can be added <a href="http://board.homeseer.com/showthread.php?t=106767">here</a>
    Cheers,
    Bob
