Sveasoft Talisman 1.05
    Just curious if anyone has gotten this working with Sveasoft Talisman firmware and what they had to do?
    -Mike
    Mike,
    I have not used Sveasoft at all, but I am sure there is some help if you search in Google.
    Cheers,
    Bob
      Blade,
      LOL, it was easier than I thought... Didn't realize the syslogd settings in the Web page of the router let you set the destination. So far, works great, great plugin!
      -Mike
        Error
        Posted a bit too early there... getting this every once in awhile:
        9/22/2005 8:41:46 PM Router Traffic Monitor Error The following exception has occurred receiving message: System.Net.Sockets.SocketException: A message sent on a datagram socket was larger than the internal message buffer or some other network limit, or the buffer used to receive a datagram into was smaller than the datagram itself at System.Net.Sockets.Socket.ReceiveFrom(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags, EndPoint& remoteEP) at HSPI_ROUTERTRAFFICMONITOR.HSPI.Receive_Messages()
        Running 1.08 upgraded to 1.09.
        -Mike
          -Mike
          Can you turn on the Very Detailed debug logging and let it run until you see this error, then send me the RTM-Detailed.log file in your Homeseer directory?
          TIA
          Cheers,
          Bob
            TIA
            Will do.
            -Mike
              You could try build 1.0.10.0 that I just posted. I attempted a fix of what I thought it could be.
              Give it a try and let me knoe. If it still does not work, then you can send me the Very Detailed log
              Cheers,
              Bob
                Blade,
                So far so good for 1.0.10; been running for over an hour with no errors. I'll let you know if it comes back...
                Thanks again,
                -Mike
                  Great! Let me know if you see it again
                  Cheers,
                  Bob
                    What router do you have?
                    Cheers,
                    Bob
                      It's a WRT54G rev 2.0. I'm about to post my log file as well for the "other computers" post in the Features news group.
                      -Mike
